LG 18650 HB6 1500mAh (Pink)
/DSC_5180.jpg)
Official specifications:
Nominal capacity: 1500mAh
Nominal voltage: 3.65V
Standard charge: 750mA with 50mA cut-off
Fast charge: 4000mA with 100mA cut-off
Maximum charge current: 4000mA
Charge voltage: 4.2V
Standard discharge: 300mA
Fast discharge: 10000mA & 20000mA
Discharge cut-off voltage: 2.0V
Maximum continuous discharge: 30000mA
Cycle life: 400 cycles to 60% with fast charge/10 A discharge.
Cycle life: 250 cycles to 60% with fast charge/20 A discharge.
Operating temperature: Charge: 0° ~ 50°C, Discharge: –20° ~ 75°
Storage temperature: 1 month: –20° ~ 60°C, 3 months: –20°C ~ 45°C, 1 year: –20°C ~ 20°C
/LG%2018650%20HB6%201500mAh%20(Pink)-info.png)
Older high current cells (Data sheet says 2014) with fairly low capacity.
/DSC_5179.jpg)
/DSC_5182.jpg)
/DSC_5183.jpg)
/DSC_5184.jpg)
/LG%2018650%20HB6%201500mAh%20(Pink)-Capacity.png)
The two batteries tracks very nicely and has nearly constant capacity at any current.
/LG%2018650%20HB6%201500mAh%20(Pink)-Temp-20.0.png)
/LG%2018650%20HB6%201500mAh%20(Pink)-Temp-30.0.png)
/LG%2018650%20HB6%201500mAh%20(Pink)-CapacityTimeHours.png)
/LG%2018650%20HB6%201500mAh%20(Pink)-CapacityTime.png)
/LG%2018650%20HB6%201500mAh%20(Pink)-Energy.png)
/LG%2018650%20HB6%201500mAh%20(Pink)-PowerLoadTime.png)
/LG%2018650%20HB6%201500mAh%20(Pink)-TripCurrent.png)
/LG%2018650%20HB6%201500mAh%20(Pink)-Charge.png)
Conclusion
This cell is a good at high current, but capacity is low by today’s standard.
Performance is very similar to LGs HB4 cell, I wonder if this cell has better lifetime (I do not have a full data sheet on HB4).
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
