Proelio Quick Charge QC 3.0 AR-QC 3.0
Official specifications:
Input: AC 100~240V 50/60Hz
Output: QC 3.0 3.6 - 6.5V 3 A / 9
12V 1.5A / 6.59V 2A (Output will according device to change) -
I got it from Aliexpress dealer Proelio Digital Specialty Store
This cheap charger arrived in plastic back inside a envelope.
Measurements
Power consumption when idle is 0.14 watt
Usb output is coded as Apple 2.4A, Samsung, DCP, QC3, Samsung-AFC, Huawei-FCP
Minimum QC3 voltage is 4.2V
Weight: 39.2g
Size: 90 x 37.8 x 25.7mm
The charger can deliver nearly 4A at 5V, this matches fine with a 3.5A rating, but is slightly above what a usb plug is rated for.
The voltage is slightly on the high side, this is nice for some devices.
At 9V the current is down to 2.8A, again well above the rating of 2A
At 12V the current is about 2.1A, rating says 1.5A.
The output current is a bit lower when using 120VAC.
Running the charger at 12V with 1.5A output current for 1 hour worked fine.
M1: 77.5°C, HS1: 88.0°C
HS1 is the switcher and M1 is the rectifier diode.
M1: 59.7°C, HS1: 81.3°C
Here HS1 is the rectifier diode.
HS1: 73.1°C
Here HS1 is the transformer
HS1: 86.1°C
Here HS1 is the switcher.
M1: 64.4°C, HS1: 86.0°C
At 0.5A the noise is 59mV rms and 1024mVpp, this is very high
At 1A the noise is 75mV rms and 1421mVpp.
At 2.5A the noise is 98mV rms and 1240mVpp.
At 9V 0.9A the noise is 105mV rms and 1765mVpp.
At 12V 1.2A the noise is 122mV rms and 1860mVpp, here the noise is even higher.
Tear down
Holding it in my vice and whacking it with a mallet broke the top off.
At the input is a fusible resistor as fuse, the switcher IC (U1) is unmarked. Between mains and low volt side is the opto coupler and a fake safety capacitor (The usual 1KV type). On the low volt side is a large rectifier diode and the smoothing capacitor.
On this side is the bridge rectifier, the QC controller (U3) and the reference (Q1: 431)
There are some slots to improve the safety, but that is not enough. With slots there must be 4mm from mains to low volt side, here is less than 2mm. Around the slot must be above 6mm, but there is only a little more than the 2mm from before.
The charger passed the 2830 volt test, but failed the 4242 volt test between mains and low volt side, this makes it unsafe for 230VAC countries.
Conclusion
This usb charger can deliver the rated current, but has lot of noise and bad safety.
Stay away.
Notes
How does a usb charger work?
