Maximum charging voltage: 4.2V (4.15V for cycle life)
Nominal voltage: 3.64V
Charge method: CC-CV
Charging current rate: 0.33C (1584mA)
Discharge cut-off voltage: 2.5V (3.0V for cycle life)
Cycle life: 3000 to 70%
Another version of the Samsung 4800mAh LiIon cell with possible high cycle life.
The two cells match very well and can handle about 10A
Conclusion
This is high cycle life batteries, but they must be treated carefully to get the long cycle life.
They are not high current batteries, but can handle a peak in current.
I wonder if I can find these anywhere in the US for sale at a good price. I currently have 33Js on long term cycle life testing. I actually need to check the data but haven’t been in that lab for a while, last I knew of they were over 600 cycles and looking really strong with capacity retention at 93 percent. These numbers are rough from memory but I’ll pull the data and share it. If these 48X perform similarly in cycle stability, they are a true winner in my book.
What’s interesting and I’ve found in other places over the years in battery research is the SOC range that yields best stability is often the same “valley” in the IR vs Eocv curve. This sort of makes intuitive sense, but it’s going to be interesting to test the hypothesis with the latest liions. That addition to your data collection is really valuable to me. So thank you!!
Necro bump I know, A guy is selling these locally for $8 CAD a piece not a bad cell for that price. Especially as they’re hard to come by in Canada. Will probably buy a couple to put in my PB2SL. I have no spare flat top 21700s either. Wonder if they’re as good as the 5000mah Wurkkos cell
