SKV89 ……
You mentioned above that in your opinion the
Lishen LR21700SF is the largest capacity battery for today.
This is wrong my friend.
If you compare Lishen to high demand with Moli P42A - Samy 40T , you will see Lishen loses a lot.
Also think that the electronic devices shut down about ± 3.2 volts.
The mAh that has delivered these three batteries at 3.2 volts
—- with 10A discharge is —-
Moli = ± 3500mAh
Samy = ± 3200 - 3300mAh
Lishen = ± 3500 - 3550mAh
—- with 20 Amps discharge, things are very different … —-
Moli = ± 3200mAh
Samy = ± 2980 - 3000mAh
Lishen = ± 2900 - 2950mAh
So it’s what you want to succeed.
On any measurement between these batteries, you’ll see Moli-Samy perform more Volts.
This means we have more power (Watts) across the discharge range.
So selecting a battery should be done with the purpose of the result we want to get and not based on the label numbers.
—- I believe you understand that I write in a spirit of friendship —-
