Good point HydrAxx. The Lishen LR2170SA cell was tested by HKJ under the LiitoKala Lii-40A wrap. It can be seen in the following graph that 15A continuous is already a bit too much for it, it is 3C rated after all:
( ಠ ͜ʖರೃ)
It may also be that the cell actually is the one tested here, rewrapped by Golisi too (S35), but the AliExpress seller is using incorrect cell photographs. Yongdeli cell as you said HydrAxx. Funny how these chinese companies like to overrate their products, 40A? :facepalm: I would use it at up to ≈20A continuous, no more.
By the way, a little birdie told me the following tri-lobe/leg top cells are likely to be manufactured by chinese OEM BAK:
https://www.aliexpress.com/item/40pcs-lot-Original-18650-3-7V-2600mAh-For-batteries-rechargeable-Battery-ICR18650-26F-safe-batteries-Industrial/32795814865.html
In this cylindrical cell basic product specifications list document (found here) I can discern it is model N18650CK, up to 2900mAh capacity and ≈35mΩ (got 35.4mΩ average in my measurements). They're 2C rated in the document, which is conservative. Pretty sure they can do 4C safely, I have 4 of them an AliExpress seller sent me instead of Samsung 25Rs (asked for half refund and got it, ended up paying €1.43/cell).
Hey! Look at the big pack you get for little money! 2 of them or more (80+ cells) does a nice e-bicycle battery already.
Cheers ^:)
