What is the total maximum power your bicycle motors will pull? As I said before, the Shockli (
Power Long Battery) cells should work nicely. I see no point in using Golisi 4300mAh (true rating 30A continuous, probably the overrated
Yodeli 26650 4300 40A rewrapped) cells unless you aim to set up some absurdly high powered bicycle or a very small battery pack, in which case I'd go with 18650s or 21700s.
Power Long Battery is manufacturing these cells for electric vehicles among other things, but of course I do not know how much will the cells last. If you aim for a durable battery pack I'd recommend choosing Samsung cells, they seem to be life cycle champions (related review: Bench Test Results: Which lasts longer? VTC6, 30Q, or HG2? @ E-CigaretteForum).
¿IMR? Sorry to say volchyonok, but as many others you've been mislead by false advertising. There are nearly no true IMR cells being commercialized right now, that chemistry is outdated. Check this article: Battery chemistry FINALLY explained @ BATTERYbro.
Do you believe the Golisi IMR26650 4300mAh is really IMR (LiMn2O4, Li-manganese)? FALSE advertising. LIES.
Do you believe the Shockli IMR26650 5500mAh is IMR? FALSE advertising again. LIES. The PLB 26650 5500mAh is a NiCoMn (NMC - INR) cell.
Most modern cells are LiNiMnCoO2 (NMC - INR), LiNiCoAlO2 (NCA), LiNiCoO2 (NCO) or maybe some other top brand secret recipe.
The LG HB6 is likely to be a true IMR cell, pretty low capacity too.
If you want a lightweight and powerful battery pack the best option probably is to make it with top brand cells (Samsung, Sony, Panasonic or LG). And as I've said before, if you need to power around 1000W of electric motors my above solution was already more than enough. Remember I've used conservative figures for my calculations, the pack above is even more powerful and if you go 14S3P it will provide over the top power if required. And remember, for accurate power output figures you need to substract loaded cells' voltage drop. Average nominal voltages (3.7/3.6V) are only seen at very low loads.
If you go with the PLB 5500mAh cells in 14S3P my conservative average sustained power output figure would be 45.5V × 50A = 2275W, with a maximum average sustained power output figure of 44.8V × 60A = 2688W.
Hope you can sort of understand this, it seems there's some language barrier.
Cheers :-)
