Shockli IMR26650 5200mAh (Black)
Official specifications:
Nominal Capacity: 5200mah (1A Discharge)
Nominal Voltage: 3.7V
Discharge Cut-off voltage: 2.6 V
Standard Charge: 1.0 A / 4.2V±0.05V (Recommend 1.0A-2.0A)
Maximum charge current: 4A
Continuous Discharge Current: 30A
MAX Discharge Current: 60A
Initial Impedance: <=20 mOhm
Cycle Life: 500 cycles to 60%
Size(mm): 26.2±0.2mm(Diameter) x 66.6±0.5 mm(Length)
Weight(g): 95±2g
Operating environment: Charging, 0°C ~ 45°C, Discharging, –20°C~60°C
Storage environment: Temp(–20°c –35°c) / Humidity (65±20%)
/Shockli%20IMR26650%205200mAh%20(Black)-info.png)
This is a high capacity and high current 26650 cell.
/DSC_6443.jpg)
/DSC_6445.jpg)
/DSC_6447.jpg)
/DSC_6448.jpg)
/DSC_6449.jpg)
/Shockli%20IMR26650%205200mAh%20(Black)-Capacity.png)
The discharge curves tracks fine and the cell has nearly constant capacity up to 15A. At 20A one of the cells got too hot and I stopped the test.
/Shockli%20IMR26650%205200mAh%20(Black)-Temp-15.0.png)
/Shockli%20IMR26650%205200mAh%20(Black)-Temp-20.0.png)
The cells gets very hot at 20A.
/Shockli%20IMR26650%205200mAh%20(Black)-Temp-30.0.png)
At 30A they discharge before I measure the heat, but they get even hotter.
/Shockli%20IMR26650%205200mAh%20(Black)-CapacityTimeHours.png)
/Shockli%20IMR26650%205200mAh%20(Black)-CapacityTime.png)
/Shockli%20IMR26650%205200mAh%20(Black)-Energy.png)
/Shockli%20IMR26650%205200mAh%20(Black)-PowerLoadTime.png)
/Shockli%20IMR26650%205200mAh%20(Black)-TripCurrent.png)
/Shockli%20IMR26650%205200mAh%20(Black)-Charge.png)
Conclusion
This battery has good capacity and can deliver a fairly high current, but the 30A/60A is too optimistic.
Notes and links
The battery was supplied by shockli.com for review.
Compare to 18650 and other batteries
