Staring IMR18650 2500mAh (Green)
/DSC_6654.jpg)
Official specifications:
Battery type: 18650 battery
Typical capacity: 2500mAh (real capacity)
Typical voltage: 3.7V
Voltage range: 4.2V~2.75V
Battery demensions: 18.23(D)*65.11(L)mm
Unit weight: 50g
Capacity density: 457Wh/L
Specific energy: 180Wh/Kg
Standred charging current: 1.1A (0.5C)
Standred discharge current: 1.1A (0.5C)
Max discharge current: 4.4A (2.0C)
Cycle life: 500T
Tempreture: –20°c~60°c
Certifications: CE, RoHS, UL
/Staring%20IMR18650%202500mAh%20(Green)-info.png)
This is high current 18650 with fairly high capacity.
/DSC_6653.jpg)
/DSC_6656.jpg)
/DSC_6657.jpg)
/DSC_6658.jpg)
/Staring%20IMR18650%202500mAh%20(Green)-Capacity.png)
The discharge curves tracks just about perfect and the batteries works well up to 20A, at 30A they are strained.
/Staring%20IMR18650%202500mAh%20(Green)-Temp-15.0.png)
/Staring%20IMR18650%202500mAh%20(Green)-Temp-20.0.png)
They gets fairly hot at 20A, but it is in the acceptable range.
/Staring%20IMR18650%202500mAh%20(Green)-Temp-30.0.png)
At 30A I would have terminated on temperature if the discharge had lasted a few second more, i.e. they are too hot.
/Staring%20IMR18650%202500mAh%20(Green)-CapacityTimeHours.png)
/Staring%20IMR18650%202500mAh%20(Green)-CapacityTime.png)
/Staring%20IMR18650%202500mAh%20(Green)-Energy.png)
/Staring%20IMR18650%202500mAh%20(Green)-PowerLoadTime.png)
/Staring%20IMR18650%202500mAh%20(Green)-TripCurrent.png)
/Staring%20IMR18650%202500mAh%20(Green)-Charge.png)
Conclusion
The cells has very good performance up to 20A continuous.
Notes and links
The batteries was supplied by Staring for a review.
Compare to 18650 and other batteries
