Vapcell INR18650 2000mAh G20 (Purple) 2019
%202019/DSC_9307.jpg)
Official specifications:
Model: G20 INR18650 2000mah 30A
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Typical Capacity: 2000mAh (0.2C discharge)
Min capacity: 1900mAh (0.2C discharge)
Weight: Max:49g
Internal resistance: Max:9mOhm AC 1kHz
Standard Charge: 2000mA,CCCV 100mA cut-off
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 30A
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-info.png)
This is a high current battery with fairly low capacity.
%202019/DSC_9305.jpg)
%202019/DSC_9306.jpg)
%202019/DSC_9309.jpg)
%202019/DSC_9310.jpg)
%202019/DSC_9311.jpg)
%202019/DSC_9312.jpg)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-Capacity.png)
The two cells are very well matched and maintain full capacity with any load up to 30A
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-Temp-15.0.png)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-Temp-20.0.png)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-Temp-30.0.png)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-CapacityTimeHours.png)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-CapacityTime.png)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-Energy.png)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-PowerLoadTime.png)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-TripCurrent.png)
%202019/Vapcell%20INR18650%202000mAh%20G20%20(Purple)%202019-Charge.png)
Conclusion
This battery looks like a good high current battery, but the good high current ability means lower capacity.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
