Vapcell INR18650 2400mAh (Purple)
Official specifications:
Model: INR18650
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 2400mAh (0.2C discharge)
Min capacity: 2300mAh (0.2C discharge)
Weight: Max:46g
Internal resistance: Max:10mOhm
Standard Charge: 1000mA,CCCV 100mA cut-off
Charging Time: 3.5hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 30000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~70°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
This is a high current cell with not that much capacity.
/DSC_5547.jpg)
/DSC_5548.jpg)
/DSC_5550.jpg)
/DSC_5551.jpg)
/DSC_5552.jpg)
/DSC_5553.jpg)
/DSC_5554.jpg)
/Vapcell%20INR18650%202400mAh%20(Purple)-Capacity.png)
The two cells tracks nicely and they can deliver 30A.
I had to skip the temperature curves, I forgot to replace the battery (It last about a year).
/Vapcell%20INR18650%202400mAh%20(Purple)-CapacityTimeHours.png)
/Vapcell%20INR18650%202400mAh%20(Purple)-CapacityTime.png)
/Vapcell%20INR18650%202400mAh%20(Purple)-Energy.png)
/Vapcell%20INR18650%202400mAh%20(Purple)-PowerLoadTime.png)
/Vapcell%20INR18650%202400mAh%20(Purple)-TripCurrent.png)
/Vapcell%20INR18650%202400mAh%20(Purple)-Charge.png)
Conclusion
The battery is a bit low in capacity, but it can deliver a lot of current.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
