Vapcell INR18650 2500mAh (Purple) 2018
%202018/DSC_5771.jpg)
Official specifications:
Model: INR18650
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 2500mAh (0.2C discharge)
Min capacity: 2400mAh (0.2C discharge)
Weight: Max:46g
Internal resistance: Max:14mOhm
Standard Charge: 1500mA,CCCV 100mA cut-off
Charging Time: 2.5hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 20000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-info.png)
A medium capacity high current cell.
%202018/DSC_5769.jpg)
%202018/DSC_5773.jpg)
%202018/DSC_5775.jpg)
%202018/DSC_5776.jpg)
%202018/DSC_5777.jpg)
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-Capacity.png)
The discharge curves looks perfect with the traces on top of each other and nearly constant capacity up to 20A.
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-Temp-20.0.png)
The cells gets warm during a 20A discharge, but not too warm.
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-Temp-30.0.png)
At 30A I stopped due to temperature.
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-CapacityTimeHours.png)
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-CapacityTime.png)
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-Energy.png)
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-PowerLoadTime.png)
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-TripCurrent.png)
%202018/Vapcell%20INR18650%202500mAh%20(Purple)%202018-Charge.png)
Conclusion
This is a very good high current cell that can deliver 20A without problems.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
