Vapcell INR20650 3000mAh (Pink)
/DSC_2095.jpg)
Official specifications:
Model: NCR20650
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.00V
Typical Capacity: 3000mAh (0.2C discharge)
Min capacity: 2900mAh (0.2C discharge)
Weight: Max:59g
Internal resistance: Max:10mOhm
Standard Charge: 1500mA,CCCV 100mA cut-off
Charging Time: 4hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 30000mA
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~70°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C
Humidity: 45-75%RH
/Vapcell%20INR20650%203000mAh%20(Pink)-info.png)
This cell is slight thicker (2mm) than 18650 cells, with about the same capacity. This means it must be a high current cell.
I had a glitch on my test station and the 0.5A value is only for one cell, not average for both.
/DSC_2090.jpg)
/DSC_2097.jpg)
/DSC_2098.jpg)
/DSC_2099.jpg)
/Vapcell%20INR20650%203000mAh%20(Pink)-Capacity.png)
The capacity is a it on the low side for a 3000mAh cell and the two cells do not track, but the high current handling is in top, it do the 30A discharge without much capacity loss.
/Vapcell%20INR20650%203000mAh%20(Pink)-Temp-20.0.png)
/Vapcell%20INR20650%203000mAh%20(Pink)-Temp-30.0.png)
It do get fairly hot at 30A and I had to stop one of the discharges.
/Vapcell%20INR20650%203000mAh%20(Pink)-CapacityTimeHours.png)
/Vapcell%20INR20650%203000mAh%20(Pink)-CapacityTime.png)
/Vapcell%20INR20650%203000mAh%20(Pink)-Energy.png)
/Vapcell%20INR20650%203000mAh%20(Pink)-PowerLoadTime.png)
/Vapcell%20INR20650%203000mAh%20(Pink)-TripCurrent.png)
/Vapcell%20INR20650%203000mAh%20(Pink)-Charge.png)
Conclusion
The battery can deliver a lot of current, but the capacity is on the low side.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
