Vapcell INR20700 3100mAh (Golden) 2018
%202018/DSC_3710.jpg)
Official specifications:
Model: INR20700
Nominal voltage: 3.6V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.50V
Typical Capacity: 3200mAh (0.2C discharge)
Min capacity: 3100Ah (0.2C discharge)
Weight: Max: 66g
Internal resistance: Max: 10mOhm (AC 1kHz)
Standard Charge: 2000mA,CCCV 100mA cut-off
Charging Time: 3hours(standard charge)
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 30A
Operating Temperature: Charging: 0°C ~ 45°C, Discharging: –20°C~75°C
Storage: Temperature –5°C~35°C, Humidity <75%RH
Standard environmental condition: Temperature: 23±5°C, Humidity: 45-75%RH
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-info.png)
This is a 20700 high current battery.
%202018/DSC_3707.jpg)
%202018/DSC_3712.jpg)
%202018/DSC_3713.jpg)
%202018/DSC_3714.jpg)
%202018/DSC_3715.jpg)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-Capacity.png)
The discharge curves for the two cells tracks nicely, capacity drops a bit with load as expected. The 30A rating looks good enough.
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-Temp-15.0.png)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-Temp-20.0.png)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-Temp-30.0.png)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-CapacityTimeHours.png)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-CapacityTime.png)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-Energy.png)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-PowerLoadTime.png)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-TripCurrent.png)
%202018/Vapcell%20INR20700%203100mAh%20(Golden)%202018-Charge.png)
Conclusion
This is a good high current cell in the 20700 size.
Notes and links
The batteries was supplied by Vapcell for review.
Compare to 18650 and other batteries
Compare to 26650 and other batteries
