Test of Windyfire 18650 2600mAh (Green)
/DSC_5917.jpg)
Official specifications:
- Brand/model: Windyfire
- Type of Battery: ICR 18650/2600mAh
- Size(mm): 18mm(Diameter) x 65mm(Length)
- Positive Shape: flat top
- Weight(g): 49±1
- Nominal Voltage: 3.7V
- Nominal Capacity: 2630mah(0.2 C Discharge)
- Minimum Capacity: 2600mah(0.2 C Discharge)
- Discharge Cut-off voltage: 3 V
- Standard Charge: 0.5 A /4.2V
- Maximum charge current: 2.6 A
- Quick Discharge Current: 5.2A
- Max Discharge Current: 7.8 A
- Initial Impedance: 40-55mOhm
- Cycle Life: 310times: discharging capacity>85%, 510times: discharging capacity>60%
- Temperature Characteristics: -10°C/0.2C >80% Capacity; 20°C/0.2C =100% Capacity;60°C/0.2C >95%* Capacity
- Charging Time: Standard charge : 5-7hours, Rapid charge : 2-3hours
- Operating environment: Charging, 0°C ~ 45°C ; 65±20%RH, Discharging, -20°C~60°C ; 65±20%RH
- Storage environment: Temp(-20°c -35°c) / Relative humidity (45-75%)
/Windyfire%2018650%202600mAh%20(Green)-info.png)
A medium capacity 18650 battery, with full specifications.
/DSC_5916.jpg)
/DSC_5919.jpg)
/DSC_5920.jpg)
/DSC_5921.jpg)
/Windyfire%2018650%202600mAh%20(Green)-Capacity.png)
Good looking curves, the two cells tracks nicely and capacity varies only a little bit with load.
/Windyfire%2018650%202600mAh%20(Green)-CapacityTimeHours.png)
/Windyfire%2018650%202600mAh%20(Green)-CapacityTime.png)
/Windyfire%2018650%202600mAh%20(Green)-Energy.png)
/Windyfire%2018650%202600mAh%20(Green)-PowerLoadTime.png)
/Windyfire%2018650%202600mAh%20(Green)-TripCurrent.png)
/Windyfire%2018650%202600mAh%20(Green)-Charge.png)
Conclusion
These 2600mAh cells has very good performance and I will rate them as acceptable.
Notes and links
Compare to 18650 and other batteries
