Xtar 4U Smart 4-Port USB charger
Official specifications:
Max 2.4A fast charging speed
Charge 4 USB devices, say goodbye to countless adapters
High efficiency with US DOE VI standard
Durable nickle-planted all-copper USB ports
100V-240V AC input, ideal for international travel
Beautiful shape, delicate design, comes with different colors
Output voltage: 5 ~ 5.25V
Output current: 2.4A (USB1) / 1A (USB 2&3&4)
Weight: 93g (3.28oz)
Size: L62.5 x W55 X H28.3(mm)
I got it from a Ebay dealer: crodex.outdoor
It arrived in a cardboard box with specifications on it.
The contents was the charger, a mains cable and a instruction sheet.
The window at the bottom is a blue led that will light up when power is connected.
Measurements
Output 1 is auto code with DCP, Samsung and Apple2.4A
Output 2-4 is usb charger (DCP)
All outputs are in parallel
Power consumption when idle is 0.15 watt
Weight: 93.8g without accessories
Size: 60 x 56 x 30.2mm
The first port could easily deliver 4A
All 4 ports could deliver over 4A, there is no individual overload protection on the ports.
When run in parallel I could draw about 5.6A at 120VAC
And the same at 230VAC
The charger could deliver 5.4A for one hour.
M1: 50.8°C, HS1: 54.9°C
HS1 is the transformer and M1 is the switcher transistor.
M1: 50.7°C, HS1: 50.9°C
M1 is the transformer.
M1: 38.1°C, HS1: 50.7°C
HS1: 41.9°C
M1: 48.6°C
M1: 44.9°C
At 0.5A the noise is 6mV rms and 158mVpp
At 1A the noise is 15mV rms and 233mVpp
At 2.5A the noise is 18mV rms and 648mVpp.
At 5A the noise is 34mV rms and 516mVpp.
Tear down
I could not break this one open, the glue was fairly good and the plastic started cracking. Cutting worked fine.
These pillars are used to keep the usb and mains connector in place, even if you are a bit hard on them when putting a plug in.
This is a very compact design, with a fuse (F1) and a inrush current limiter (RT: NTC) at the input, followed by a common mode coil (L1 & L2). There is also an inductor (L3) between some of the smoothing capacitors. On the other side of the mains connectors is the mains switcher transistor on a small heatsink. Beside the transformer, next to the black isolation is a safety capacitor.
The low volt side only has the capacitors and the usb connectors.
The mains switcher transistor on its heatsink.
On this side are the chips and the bridge rectifier (DB1). The mains switcher is below the switcher transistor.
The low volt side has a power mos for rectification (Q3) controlled from a synchronous controller chip (U2). There is one auto coding chip (U3), but space for more (U4 & U5). The blue led (LED) is mounted on this side.
The black isolation sheet is very important to get enough isolation distance.
Safety distances looks fine.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
This charger works fine and is safe. One auto coding port is a bit sparse, but then most devices knows standard usb coding and will charger at a decent speed on it. This means the charger is fine for one power hungry device and a couple of other devices (Usb powered battery chargers do usual not check coding and can be used on any port getting full power).
It is a good charger, but with some power limitations.
Notes
How does a usb charger work?
