Test / Review: Unknown 17355 3.0V 1000mAh (Green)
Official specifications:
  • Capacity: 1000mAh
  • Voltage: 3.0V
  • Rechargeable Times: Up to 500 times
  • Size: 33.5mm(Length ) x 17mm(Diameter )
This is IFR batteries, i.e. LiFePo4 with a maximum charge voltage of 3.6 volt. The actual capacity is much lower than specified.
The two tested batteries has very different capacity.
The charge curve is a typical LiFePo4 charge curve (Voltage drops from 3.6 to 3.4 volt when charge is terminated).
Conclusion
These batteries are fairly cheap, but that does not excuse the huge difference in capacity or the way overstated capacity, I will call these batteries bad.
Notes and links
CR123A and rechargeable substitutes
Thanks, I’ve been using these batteries for several years and can only confirm those findings. Pathetic capacity and high internal resistance. It’s hard to believe Lifepo4 can have such big resistance.
It seems chinese inflation has surpassed 300% and is now at least 400%
Thanks a lot for the review! Frontpage’d and Sticky’d.
China has to be cutting edge.
“Conclusion
These batteries are fairly cheap, but that does not excuse the huge difference in capacity or the way overstated capacity, I will call these batteries bad”.
Agreed!
