TH-T60 upgrade Help!
Hello everyone,
I have had this Light a UltraFire TH-T60 for a couple years and it seen its last day. Looking to replace the led and driver. Open to any suggestion from all. I like to get as much Throw as possible with this light. In the market for a new light with good Throw any suggestion will help me in what my next light will be. I do have a S2+ on the way with XML2 U2 hope is has some good throw. Thanks all!
If you really want throw start with a different host. If you just want it more throwy (is that a word?) then the basic concept is a small emitter, a big deep reflector, little wasted light to the sides (dedome) and crank up the power.
Nothing wrong with experimenting but there are a nice number of inexpensive lights that mod nicely for throwing (Iā€™m a flood guy) mules are ok by me if they have enough grunt.
.02
for Throw get a XPL HI V2-3A neutral white
a good light is the Convoy C8 if you buy the new one
with new driver UI, DTP and AR glas
https://www.aliexpress.com/item/Clear-Convoy-C8-with-XPL-HI-LED-copper-DTP-board-and-ar-coated-inside-new-firmware/32732511943.html?spm=2114.01010208.3.1.kJbWZT&ws_ab_test=searchweb0_0,searchweb201602_5_10065_10068_10084_10083_10080_10082_10081_10060_10061_10062_10056_10055_10037_10054_10059_10032_10078_10079_10077_10073_10096_10070_10052_423_10050_10051_424,searchweb201603_1&btsid=e3758a95-2394-4fc5-91b7-1061d8b053e4
a website with high end LEDs and DTP boards is for example
http://intl-outdoor.com/noctigon-xp16-cree-xpl-high-intensity-v2-3a-p-901.html
or
http://www.mtnelectronics.com/index.php?route=product/product&path=60_106&product_id=575
with those DTP boards you can drive the LED up to 5A without a problem, highter is possible but not recommended
driver
https://de.aliexpress.com/item/7135x3-7135x4-7135x6-7135x8-with-new-firmware/32734523412.html?spm=2114.13010608.0.0.xezwgy&detailNewVersion=&categoryId=150410
you can add more 7135 for higher current
