default we assemble 3 cree xml2 u2-1a in M170 flashlight.
this is the link: M170
also we have other optional cree xml2 leds:
T6-2A
T6-3A
T6-3B
T5-4A
T6-4C
T5-5A1
T4-5A3
T5-5B1
T3-6A1
T3-6A3
T3-6B1
T4-6B3
T2-7A2
T4-7A3
T4-7A4
T2-7B2
T2-7C1
T3-7C3
T2-7C2
T3-7D3
T2-8A2
T2-8B4
pls note your selection , and email me to comfirm that it’s in stock
Utilization interface:
High > Middle > Low mode:
Press the button for 1 second to turn on the flashlight and enters middle brightness mode, then single click to switch in high > middle > low brightness modes
Variable brightness:
When the flashlight is on, single click the button then immediately press and hold the button to enter dimming mode: First time single click + long press will reduces the brightness, release your finger at the brightness you want (it flashes at the lowest brightness); Second time single click + long press will increases the brightness (it flashes at the highest brightness)
Flashing mode:
When the flashlight is on, triple click the button to enter flashing modes, then single click to switch in fast strobe w/ intervals > fast strobe > beacon > slow strobe. Long press to quit falshing mode
SOS mode:
When the flashlight is on, quadruple click the button the enter SOS mode. Then press for 1 second back to middle brightness mode (long press to turn off)
specifications
color: black
material : aluminum alloy
waterproof : ipx8
lowvoltage warning : Breathing flash
reflector type : SMO / aluminum
switch : side / electronic
tail stand : yes
batteries included : no
requilred battery count : 4pcs 18650
accessorries : handle, screw, conventer
weight : 700g
