Welcome back to the 400 Lumens Challenge!
It’s been a while since Part 5. I originally said the next round would feature an Emisar DW4 mule with 519A 3500K LEDs and a Boost driver. Well… that test never really got me excited enough to actually do it. I kept putting Part 6 aside. So here we are, 10 months later…
I finally had a much more interesting contender sitting on the shelf: another Noctigon KR1 flavor! This time, equipped with an LHP531 @ 3000K.
The LED was ordered directly from Convoy on a 20mm MCPCB back in February 2026, and then did an emitter swap. The host originally received an SFT-25R from Kaidomain, which unfortunately had a pretty horrible tint.
This KR1 uses the same 9A driver as the other KR1s tested earlier in the challenge.
And as always, the goal is to get as close as possible to 400 lumens.
Here’s the setup:
| Brand | Model | LED | CCT | Driver | Cell | Set Level | Ambient |
| Noctigon | KR1 | LHP531 | 3000K | 9A Linear | VapCell N40 | 86/150 | 21°C |
Note that the DC fix wasn’t there during the test
These numbers look pretty good to me!
Now let’s see how it compares with the other KR1 flavors:
Compared with the other KR1s from Part 1, the LHP531 3000K actually performs surprisingly well! Despite its much warmer CCT, it manages to outperform both the SFT-25R and the SFT-40.
That’s a pretty impressive result for a 3000K emitter.
Looking back at the previous tests, the FFL X4Q from Part 2 seemed like an interesting candidate for comparison. The X4Q was running three FFL high-CRI emitters at 3700K, powered by the Lume X1 driver:
The LHP531 3000K in the KR1 delivered a runtime surprisingly close to that of the X4Q 3700K, despite the X4Q having three emitters, a 700K higher CCT, and a more sophisticated driver.
The high-CRI emitters in the X4Q are not an advantage when it comes to raw runtime. Their lower efficiency actually work against them.
In the end, the two setups land surprisingly close to each other.
So, after all this time, I’m actually glad I skipped the DW4 and picked up the soldering iron instead.
Next up: you guessed it… another KR1!
This time, it will be equipped with an LHP531 at 4000K and a 12A driver. Apparently, the KR1 really is one of my favorite lights.
Stay tuned!
• Part 1 - 3 KR1 Flavors Face Off! [here].
• Part 2 - FFL X4Q Comet [ here]
• Part 3 - Wurkkos TS30S Pro [ here]
• Part 4 - Fireflylite T9R (FFL909MX) [ here]
• Part 5 - Skilhunt M300 V2 Nichia 144AR [ here]
