JasonWW
(JasonWW)
110
I was able to make my 3rd set of lights work. These measure 4 times the lux of the stock bulbs.
I used my “dremel” tool to cut out the plastic retaining ring in order to slide it on further. I had to cut more than I originally thought.
Stock location:
New location:
The plastic base slides all the way down flush with the tapered edge of the aluminum housing.
I was able to get the leds to line up perfectly.
The end result is a stock beam pattern, but much, much brighter. Even at iso 100 and the exposure turned all the way down this led light is still over exposed. It’s not the best looking beam pattern, but it is stock and I can’t get any better short of installing a projector.
I still need to figure out a way to hold the bulb tight to the socket so it doesn’t rotate or move around. Right now the double o-rings seem to hold it very snugly, but I don’t trust them long term.
