mattlward
(mattlward)
11
Correct, but by keeping the cells in a family and charging them at the same time and rate the voltage differential is very small. I do not think one would ever have a problem with decent cells within a small handful of tenths of volts apart. Now it you start mixing cells or have large voltage spreads, I am not so sure you would not have a problem. Also, if mixing good low resistance cells with higher resistance cells, the question becomes (in my mind) am I charging the high resistance cells above the manufacturers charge rate?
