The Effects of Chromatic Aberration Demonstrated
What is Chromatic Aberration?
Simply put, it is a difference of focal length experienced between a blue color and a red color when a lens is used to focus an LED image. Blue has a shorter focal length, red has a longer focal length. This is because the wavelength of the color striking a surface will determine how much that wavelength bends, or refracts, when it passes through the lens. So, blue bends more sharply than red. Purple bends more sharply than blue as it is an even shorter wavelength, but typically in a white-light system we consider the spectrum ends to be blue and red.
Using a lens that creates a projection of the LED’s image, brings with it the described effects above. If the lens system is optimized, chromatic aberration will become very low. Achromatic and apochromatic lenses are designed to reduce chromatic aberration by using 2 and 3 lens types together, respectively. These lenses are typically cemented/glued together so that they remain one working component in a system. The same effect can be witnessed by using combinations of lenses with space between them though, they don’t have to be glued together to generate similar effects.
When all of the light is in-focus and the system is designed optimally, the colors will appear to be as one, without any blur when the image is projected. Because of chromatic aberration however, the image will typically be missing some of the light from one spectrum end or the other, depending upon where you focus the light at.
For those who do not know it, the LED creates a narrow band of blue light from the semi-conductor region. On top of that region, the phosphor layer is placed. When the phosphor is excited by higher energy blue light striking it, a combination of lower energy colors come out of the phosphor. It is also the layer responsible for green, yellow, orange, and red production. In reality, the phosphor layer is not very thick, and the two regions of the LED’s light production are extremely close to one another.
A simple experiment was setup to show the described effect. It was done through an aspheric lens that is commonly used in some cheaper lights. First, the dome of an XM-L was removed, then some of the yellow phosphor was scratched off. This allowed the blue emitting region of the semi-conductor to be exposed by itself in one area.
In the photo you can see the tint change as focus changes to be upon different colors. Slices of each image are swapped for a comparison. Since lux is dependent upon colors, we can summarize that changing the primary tint which is in-focus will also change the measured lux of an LED. It is also something to note that, low F# lenses are more likely to yield amounts of chromatic aberration than higher F# lenses, since the bending of light which occurs is more drastic.
If you are trying to attain the highest lux output and intensity from a focused light, a single lens with a very large curvature compared to its diameter will almost always be what is a low F# lens, for example a 50mm diameter with a 25mmEFL will be around a 0.5 F#. This will exhibit more chromatic aberration in almost all circumstances than a lens which is 50mm diameter with a 35 or 40mmEFL, which may be a 0.7 or 0.8 F# lens. Though you may find this lens too be too long of a FL for your specific light, use of a pre-collimator lens will bring the system FL shorter again, leading one to believe the F# will once again be brought down, but what happens in reality; although the system FL is brought back down, the chromatic aberration will not increase as it would with one single lens. One will often find that lux and intensity will actually go up by splitting the bending of light between these two lenses, by use of a pre-collimator.
The blue/yellow seen around images below represents light which could be used within the image to increase lux, but due to a single lens with low F#, it cannot be fully used, because of chromatic aberration. When testing lenses, it is important to note the amount of blur seen. If there is a bit of blur that you notice when you find maximum lux, you may benefit from the use of a pre-collimator to further increase the measured lux.
PRE-COLLIMATORS?
Sometimes, substantial increases in intensity will occur by simple use of a longer-FL primary objective lens, and a possibly “cheap”, small, pre-collimator lens placed near the (de-domed) LED. Let’s back up a moment. This longer-FL lens would mean that alone and by itself in the main lens position, the flashlightlight-body may not produce a gap between the LED and the lens which is far enough apart to actually focus clearly. When this happens, focus can be achieved by using another positive lens between LED and objective lens. This becomes known as the “pre-collimation” lens, now likely sounding more self-explanatory. It can in fact be of a different material, such as a polymer rather than a glass, to create projections that the objective lens design will make more use of than previously and without a collimator at all. The formulas say that only image size will change when another lens is used yo do this. Those same formulas are not taking into account the correction of aberrations, and their result on final lux output, as well as other phenomenon which occur with LEDs in different scenarios. These formulas assume a perfect lens produced in a perfect world. Some experimenting with the small-distance gap between die and pre-collimator lens will likely show optimal placements of this first lens which will result in increased candela at a specific location. An ordinary setup to test this could be a simple plastic washer set, each washer being ground to different thicknesses, or stacked at different distances from the LED die surface to mount the pre-collimator. I.E., distances of 0.5mm, 0.75mm, 1.0mm, 1.5mm, 2.0mm—from die surface might be tried and lux values recorded. Note, as this first gap increases, it may be further beneficial to increase the pre-collimator diameter to capture more light, since light leaves the (de-domed) LED at such high angles. Before the recycling of light was used to optimally transfer more light to the objective lens, this was a common practice used on some of the highest throwing lights which did not use light recycling. The benefit greatly outweighed the loss which occurs when there are more total lens surfaces to reflect and waste light. If this lens were to have a slight domed meniscus profile on the inside (typically the “plano” side as it would normally be, facing the LED), and was placed very near the LED, some recycling effects would actually be obtained just due to surface reflection bounce between die and lens surface. The closer the two become, the higher the recycling would become due to reflection. As you would imagine, this effect was more likely to occur as the pre-collimator became closer to the die itself, because any non-coherent reflected light scatter would be forced to strike the phosphor again.
This simple photo demonstrates how measured intensity can vary by the known fact that color temperature indeed effects the witnessed brightness of projected light as seen by the human eye. The effect is known to become greater with lower F# lenses, in part because of a few reasons, but a simple way to look at it could be summed up as happening because of their large curvature and the effect this has on high-angle light rays.
