DPS5020/DPS5015 typical output fuse burned: 5V1A short output, no output match, red LED lighting
hello, this video shows the CC-CV mode charging voltage and current curve, at first when it is CC mode, current is constant, the output voltage will rise to peak voltage, then it turns to CV mode, voltage constant, current will reduce to a low value
hello, in RD series power supply box, there is a temperature sensor cable, you can attach it on the battery being charged, and set a cutoff current in the menu, when the battery tempterature is higher than that value, the output will be cut off for safety
hello, I see a customer bought a case C1 for his RK6006, normally case C1 is only for DPS3003/DPS3005/DPS5005, after assembly it is still DC to DC, it does not have input AC to DC PSU, and since it is for DPS power supply, it can use 60V max input, so that use this case you will not get 60V DC output from your RK6006, please notice that
@RD_tech Do you have plans for a 72V version?
no, sorry, we don’t have
if you find your RD power supply input power disconnects and recovers in short time, it reboots and output not normal, it is because when input power disconnected, main control board lost power, but power board still works since the capacitor has remaining power, then the data of them do not match, you just disconnect the input power totally, and it is ok
