The new product RD6030(W) 60V 30A big current power supply is coming!
I have the 800 case , but was not supplied the cable to be able to use the Temp sensing cable . How do I buy this cable. Thanks
40 mm size fan?
please contact us on aliexpress, show us the case you have, and we can give you the special link to the cable
yes 40mm fan, it changes the “*”
Here’s my case.
I see it has the hole, it should have this board, you can contact us on aliexpress, we give you the link
hello, for our power supply, for normal load, you can use the full output, but if you connect inductive load like motor, please limit the current in 1/3 range, like RD6012 12A power supply, use in 4A to protect the device from instant high current
hello, for our power supply name, it is its max output, like RD6012, it can output 60V 12A, some customers ask if they use 30V output, can the output current double? no, at any voltage this power supply can output 12A max
when using DPS/DPH series power supplies which have separate power board, please put the connection under the power board, if the connection cable touch the capacitors on the pcb board, the display will be affected
RK6006-C fan is controlled by the RK6006 and ac to dc PSU together, for RK6006, output current over 5A or temperature higher than 65℃, the fan will work, or the AC to DC part is hot, it will work too, so sometimes at standby mode the fan will also work
RK6006-C can use both 100-120V AC/200-240V AC input, it is set to 220V input by factory default, if you use 110V AC, please find the red switch on the side, put it to 110V gear and it is OK
For our RD series power supplies, they have 3 display style, you can set it in the setting page, or you can just press the left/right direction buttons to adjust the display style, it is much faster
