I had two questions, but a read of the original post answered one question. So hereās my second question: why is it that small gas engines are so much noisier than large gas engines?
You might think the smaller engine is noisier because itās usually higher pitched. Humans donāt hear sound linearly. We have whatās called Flecther Munsun Curves. We are less sensitive to lower frequencies so a larger piston tends to sound deeper and quieter while a smaller piston is more āwhinyā and louder.
Also, smaller engines tend to have smaller mufflers so as not to reduce too much power.
This may not be budget but will just change the lens to black one, https://www.allmoparparts.com/sku/264274bk.html. It is from Recon and the price is not too nice and would it be a best choice for a recon light? Also, not sure if it legal to have one lens to be black and the other whiteā¦but would hope I can do that.
I would see what the cutoff pattern looks like. Iāve seen a lot of jeeps with projectors that just glared oncoming traffic like crazy. If these give you a sharp cutoff pattern and they are adjusted right, they might be okay.
Virence doesnāt appear to have flashlight-sized and -shaped LEDs, unless Iām misunderstanding the pages there.
Iād be looking for 20mm stars to drop into existing flashlights replacing the cold blue stock emitters.
His page seems to offer the largish square emitters which wouldnāt work with normal reflectors.
Virenceās CRI offerings do seem to be better than anything Iām aware of.
144A is a straight swap for an XHP50/50.2, 219 and 319 are 3535 pad. Optisolis and E21A are similar to XP-E or smaller and work well in small lights that have low current like AAA keychain plus he also has āquadtrixā boards for them that allow 4 to be mounted very close together and centered in a large enough reflector or TIR in an S2, Skilhunt H03 and similar.
Yeh. I grabbed the narsim .pdf, and in the āadvanced configurationā table at the extreme-right, the 2nd option is battery-level by indicator-light only.
Gotta follow the blue arrows, I donāt wanna try āinterpretingā it and have you initiate the self-destruct feature.
Ok, go back into the advance configuration - first 3 steps only. Don't press anything, but watch how it works - should be 3 settings, watch the blinks, see how it works. Keep in mind the setting you want to change is setting #2, the middle one. Each setting will timeout, then go to the next, when all done it will blink 4 times fast.
So another words, just see how it works -- don't change anything yet. If you feel comfortable recognizing the 3 distinct settings, then we can try setting them.
2 clicks enable, 1 click disables. I think you disabled setting #3 possibly.
So to fix it, you want to enable setting #2 and setting #3. Below is the snippet form the original Q8 manual (.doc file). Not sure, but think this is my version, or based on my version (what I wrote). Hope this all helps!
Configuration UI Operation
For Ramping, hold the button for 8 seconds, and for Mode Sets, hold the button for 3.2 seconds to activate the main Configuration UI settings. The light blinks 2 times quickly, and once slowly to indicate Configuration UI mode is active. As listed below, you can change or leave any of these settings ā thereās no need to set each one. Clicks choose the value for each setting, and each click will blink the light to acknowledge the click. If you disable Ramping, then the next setting will be #2 under Mode Sets, and vice versa. If no clicks are entered in 3.5 seconds, the light jumps to the next configuration setting indicated by 2 quick blinks and slow blinks of the number for what setting it is (ex: 3 slow blinks means the 3rd setting). You can bypass the timeout by doing a press&hold to skip to the next setting. If you continue to hold it, it will exit configuration UI settings mode altogether, indicated by 4 quick blinks.
For thermal stepdown, the main LEDs will go to max output, if you click in under 5 secs, the set temperature will be unaffected, but more than 5 secs, the current temperature reading will be recorded as the new temperature to use for the stepdown ā be sure you set it high enough ā light should be hot enough to barely hold, or even hotter. Factory default temperature is 55C, but calibration will vary from unit to unit. When timed stepdown is chosen, it will blink, prompting to enter the choice of time, 1-7 clicks as described below.
To reset settings to factory defaults, in firmware version # display, press&hold for at least 1.2 seconds.
Activated from Battery Check mode by doing a press&hold for at least 1.2 seconds. The light blinks twice quickly, and once slowly. 3 settings summarized below, and operates the same as the main configuration UI.
