If the lower levels work fine and it is only the brightest levels, sounds like a mosfet issue, the lower levels are handled by the resistor bank. The high modes are handled by the dedicated FET.
You said you replaced it but something with that FET makes the most sense. If you have reflowed the driver, it is possible one of the resistors or pins leading to that FET was messed up and is preventing the FET from getting the signal.
