Thermal conductivity
Need some advice from BLF community…
1. Regarding thermal conductivity, is it better to join, lets say two (or more) flat plates of copper or aluminum (assuming that they are lapped and polished), by soldering or screwing together with thermal paste in between?
2. Is there a thermal adhesive that glues together hard enough to hold but not as hard as “Arctic Silver Alumina”? I avoid to use Arctic Alumina because it is very hard to remove when cured and I haven’t found anything that holds and at the same time provides good thermal conductivity.
Thanks
Hello!
  1. By soldering, of course, much higher thermal conductivity (50W/m×K for Sn63Pb37).
  2. Solder! Only if you can heat up the whole thing, that is.
Cheers ^:)
1. Thanks, that answers my question.
2. Thanks again, but that is not what I’m looking for. Arctic alumina is much easier to remove by heating then solder. I want to avoid heating, I need something between thermal epoxy and regular thermal paste. I was using “Fujik” thermal glue from FastTech but it has poor thermal conductivity in comparison to Arctic products.
Hi!
Did you took a peek a low melting solders like Rose's metal?
For example: Rose's metal / Rose metal (Bismuth, Lead, Tin alloy) 75 g. LOW MELTING SOLDER
Not expensive, but I don't know how easy is that stuff to work with.
Cheers ^:)
Melting point is 93-96 °C
I think some light will be able to melt it while running…
What some people do is use grease but with a bit of adhesive around the edges, clamping until the adhesive sets. If you are joining flexible plates then glue, screws, or solder will be your choices
Will try, thanks :+1: .
Screwing together with grease/paste (not hardened). If you are lapping the parts and mechanically pressing the parts together, any decent thermal grease will work. You want as little material between the plates as possible to get maximum direct copper to copper contact. So stuff that hardens would be inferior in this situation.
