in our flashlight applications we try to ensure both surfaces are flat and smooth as is practical.
this reduces the dependency on the type of compound used.
then i use the same generic white compound i use when replacing igbt /ipm modules in motor drives.
its silicone oil and zinc oxide based.iirc its cooler master ice fusion.
cheap and does not dry out. some of these ipm’s are huge so low cost is important.
too many lights are built with sloppy surfaces that negate even the best mcpcb or compound.
speaking of mcpcb there is now no reason to use aluminum mcpcb with dielectric layers.
copper dtp serve as a very effective heat spreader with a low thermal resistance from the die to the copper.
makes life easier passing the heat to the lights body.
