ThorFire VG-10s REVIEW, short and sweet with lots of pictures
Since I’m about the Jillionth person to review this light I’m gonna give you the bottom lines right here, right now.
THE BASICS:
A good looking light that has the basics covered: Stainless bezel, AR coated glass, thick switch boot, good pocket clip. Black powder coat is even and looks durable. That’s a lot for a 23.00$ light! This alone makes the light worth owning.
MACHINING:
Couple of rough edges, no big deal. Most surfaces are well machined and smooth.
Threads are well done, lubricated and go together smoothly. Heat fins are awesome! THIS LIGHT STAYS COOL!
Reflector is machined aluminium, pretty thick, normally found on more expensive lights, no doubt adds to heat dispersion capabilities.
SWITCH:
Switch button, PCB, and spring good quality, no upgrade needed. Design simple and looks durable with plastic spacer and thick brass retaining ring. Only mod I’ll make is spring bypass.
DRIVER:
Good spring, thick multi-layer PCB, thick wires and thick traces on board, reverse thread brass retaining ring adequate. Only mod needed is spring bypass.
MCPCB:
Once again I am impressed, this thing is thick copper!
Well seated and plenty of heat transfer goo. XPL2 has its dome intact. Might eventually switch out for a Noctigon with a better color cast.
Led is well centered.
PERFORMANCE:
Moonlight level. I increased the color of this image to show you my first real issue with this light. The AR coating combined with the yellow reflections combine to give this light’s spot a ‘rainbowy’ spread. What you see here shows up at the other end…
Moonlight level on white box, you can see hints of what I’m talking about.
Full bright on white wall, I saturated the color again (not by much though) to show the color effect. Inside on a white wall you will notice this, under normal use you probably won’t.
It’s dusk outside, and this is full bright.
VERDICT:
This light is BRIGHT, it stays COOL, it is next to the perfect SIZE, it is WELL-MADE, and needs very little modification to put out its full potential. It is a true every-day-all-day carry light. Only issue is rainbowy color cast which doesn’t affect every-day use. I am happy to own it.
