Thread dope
Wondering if anybody can recommend a semi-removable thread dope to use in place of a thread locker. I’ve used Permatex High Performance Thread Sealant (#56521) in the past, but its still a little stronger than I’d like. Greases and anti-seize will be too much of a lubricant while I think even a low strenght thread locker would be more than desired. Maybe a different thread sealant like the permatex PTFE thread sealant? The High Performance is rated for 40 in-lb break away torque on a 3/8NPT fitting while the PTFE sealant does not seem to list a break away torque rating.
Actually now that I think about it I do have some Vibra-tite VC-3 in my knife maintenance kit that might be a good option. Hmm…
Maybe try simple silcone sealant? Watch out for chemical oring compatibility though
You don’t say what you’re using this for. Ptfe is technically a lubricant. Yes it also fills gaps. Any pipe thread sealant that says “soft set” might be a good choice but again you didn’t specify what you’re doing. Any and every bolt on a vehicle in the rust belt that doesn’t have some sort of factory coating on it for me gets either anti seize
or a soft set pipe thread sealant. Blue Magic in the US or Gray Magic in Canada as I see you are next to the border.
Quark head after an emitter swap :wink:
I have used the high performance thread sealant on my last one but it sets far too tight… Not even sure if it will come off again or not as I haven’t tried that hard (but from other uses it generally breaks free rather easily with hand tools).
I’m about 80% decided that I’ll use a dab of VC-3 this time around.
Probably don’t want to use anything with silicone around an optical window, surface or lens. The silicone will outgas and coat the surface, and it can never be cleaned off without damage to the optic. This is like instant death to telescopes.
Really?? I never knew this.
Thanks kennybobby for the additional precaution. On this point, outgassing from many sealants, adhesives and lockers probably wouldn’t be friendly to optical surfaces. Silicone is at the extreme end from my direct experience (right up there with super glue)
I used to have a container of a string like dope made for steam radiators . I don’t know what it was called but it certainly stopped any steam leaks in radiator on/off valves
Could you use bees wax like they do for setting the ferrite cores in radios?
Dope thread!
