I’m looking for a led thrower that can take rechargeable batteries. I want it to be able to shine 200+ yards with a small to medium spread. I would like for it to have high, medium, and low. I want basically a handheld spotlight that its also weapon mountable. I’ve been liking towards the trustfire recoil or the trustfire 3t6 because of the option of 2 or 3 rechargeable cell capability but I’m not sure it has the range I’m looking for. Thanks everyone.
Are you okay with using Li-ion batteries? If so I would suggest either the Jacob A60 or the Fandyfire STL-V6.
Like it…. But it doesnt reach very far. The K40 or TN31 might be more along the lines of what you are looking for.
Scaru- yes li-ion would be great i will need the batteries, charger, and light.
Dale- that’s what i was thinking and thank you i will look into the lights you recommend
YW
would those short fatties be able to be weapon mounted though? i know single cell lights are fairly easy to mount, but im not sure what could be used for those fatties
The TN31 and K40 are not exactly gun mountable. If you need a li-ion battery and charger I would recommend these.
Those should cover everything you need.
Depends on the weapon……
even the stl-v6 would need some sort of spacer on it to get room for the head
So would the other throwers, since they all have a big hand.
What sort of weapon are you thinking of hooking the light to?
yeah i know, just letting the OP know so he knows what he will need for mounting it to a weapon
I can put the mpp1 on my shotgun ( no reason to but I can) by using a bottom mount picatinny rail and a 3 position mount. Not sure if the light scaru suggested is larger but it can be done even if it’s not practical. A tactical light and night vision scope would be better imo.
not sure that ‘fast reply’ is working out for ya… Lolol
If you get the items from Fasttech make sure to use the discount code to get the %5 off. Save yourself some cash
Sorry about all the fast replies lol. Phone is a little crazy. I’m trying to mount it to a m16 and possibly a shotgun. I’m active duty military so a bright light would really be great.
I think the Armytek Predator G2 would work. >)
I’m sure all the lights suggested would suit your handheld needs but I’m not sure about the mountable needs. I’m no expert but if you’re using it for your service needs you may want to search around and find some lights people have tested on an m16 for some time. I’m not saying any light wouldn’t work but heeding someone’s advice who’s been there done that (why I read blf) with lights on that rifle might be your best course of action. If it’s for personal use, have fun lighting stuff up, literally and figuratively.
If you do decide to use a thrower on your rifle please let US know how it goes.
How good an idea is it to have 2 - 3 18650’s bouncing about under recoil? Particularly if full auto is available?
Wouldn’t a potted single cell light like the Jacobs a60 or an aspheric lense on a c8 sized light be a better bet? And do you want a tape switch or is a tail clicky acceptable? You also want something with mode memory, or that always starts in high or else you’ll be up and down the modes every time you switch on
A clickie would be nice and a pressure switch when its mounted. Mode memory is good or a rotary selector. As far as mounting i can offset it infront of the hand guards and should allow the bigger head. How are the zoomable lights with aspherical lens. I think it would be nice to just rotate the head and have spot or flood.
