Thrunite Archer 2A v2 XP-L and JETBeam WL-S4 MT-G2
Thrunite Archer 2A v2 Cree XPL - 2AXPL
Features,
- Upgraded version of the Archer 2A with more user-friendly UI and updated LED.
- Added side switch for easy operation.
- Five modes: firefly, low, medium, high and strobe.
- Momentary “forward clicky” tactical switch.
- U shape groove at the tail for easy activation as well as preventing accidentally activation.
- Reversible and removable stainless steel pocket clip with titanium coating for durability.
  • Memory function to set any mode(except for strobe) for immediate use.
Specifications:
- LED: CREE XP-L V6 LED with a lifespan of 20+ years of run time.
- Modes & Run-time: Firefly:0.055lumen(672 hours); Low:17lumen(96 hours); Medium:75lumen(11 hours); High:450lumen(100 minutes); Strobe:450lumen(140 minutes).
- Max output: 450lumen using two AA batteries. Run time: 672hours (Firefly mode)
- Battery: 2 AA batteries(not included), Working voltage: 0.9v to 4.2v
- Max beam distance: 130 meters. Peak beam intensity: 4232 cd.
- Impact resistant: 2 meters, Waterproof to IPX-8 Standard (1.5meters)
- Weight: 75g without battery.
  • Dimensions: 160mm in length, 23mm bezel diameter.
JETBeam WL-S4 MT-G2 2600lm Flashlight - JBMTG2
Features:
LED: Cree MT-G2
Maximum output: 2600 lumens
Max beam distance 380meters
Precise aluminum reflector
Toughened ultra-clear mineral glass with anti-reflective coating
Aero grade aluminum alloy with Type III hard-anodized anti-abrasive finish of grey
Power by RCR123A*4/CR123A*4 or 18650*2
Switch: Dual switch (tail and side)
Impact-resistant accords with US MIL-STD-810F (1.5 meters).
Size: Diameter 63mm (Head), 25.4mm (Body), 26.5mm (Tail), Length: 242mm
Weight: 272g (without batteries)
Output and Runtime:
Turbo 2600lm (2.8hrs)
High 1050lm (3hrs)
Mid 360lm (6hrs)
Low 100lm (13hrs)
Ultralow 5lm (180hrs)
Thrunite Archer at $45.95 and
JETBeam WL-S4 at $109.00 at time of this post.
Private prices and E-coupons for both available by PM.
The Thrunite Arcer 2A V2 seems an Olight….
Ciao
Wow the jetbeam has 2600 lumens for 2.8 hours from 2x 18650?
Lol must step down straight away if it gets 1050 for 3 hours
Jetbeam looks nice. 9.5” long. Seven modes. Great price after discount.
Could get those coupons?
