The Thrunite Archer UV is a new AA sized UV keychain flashlight. The Archer UV uses 365nm wavelength emitter in a shallow smooth reflector. There is no AA battery included in the package so you will have to provide your own. The Archer UV is compatible with both alkaline and NiMH AA battery chemistries. The light is IPX-7 water resistant and impact resistant to 1.5 meters.
There is no switch on the flashlight and the light is operated by twisting the head on or off. There is subtle knurling on the head to ensure good grip while operating. The UV light has enough flood for up close tasks but still can light up items across the room.
The UI is very simple as you tighten the head to turn on and loosen to turn off. There is only a single mode. Runtime is about 45 minutes with the AA battery.
Things I like:
- Simple to operate
Things I don’t like:
- Only one mode
