The Thrunite Catapult Mini Pro is an updated version of the Catapult Mini V2. This new model features what I believe is the SFT70 emitter. The emitter is cool white and rated for 2500 lumens and 80,200 candela. The beam profile is a large sized hotspot with usable spill. The hot spot is very clean and round with a sharp corona. There is no green in the beam and is a very clean crisp white. Like the V2, the Catapult Mini Pro features a traditional smooth reflector instead of a TIR lens. The neat thing about this model is that it can be ran with the included 18350 tube and battery or with the included 18650 extension tube (18650 battery not included). Included in the package is the extension tube, 1100 mah 18350 battery, usb c cable, spare o-rings, lanyard, and spare usb cover.
The Catapult Mini Pro features onboard charging via USB-C. The rubber charging port is located on the side of the light which fits securely in place. The switch is the classic Thrunite clicky side switch. The switch also acts as a battery indicator to show battery status when the light is on. Blue is fully charged and red means the light needs to be charged. The knurling is similar to other new models in Thrunite’s lineup and feels good in hand. The bezel has updated texture instead of being smooth is more aggressive but not sharp.
The UI is as follows. A single press turns the light onto the last memorized mode. A long press from off activates moonlight. Hold while in moonlight will lock out the light. Hold while on cycles through low, medium, and hight. A double click from on or off will activate the 2500 lumen turbo mode. A triple click will activate strobe. Using the 18350 battery, the turbo mode will run out its highest setting for only 20 seconds before ramping down to 680 lumens for 60 minutes. The high mode is rated for 1233 lumens for 60 seconds then will step down to 660 lumens for 65 minutes. Medium mode is rated for 309 lumens for 2.5 hours and low mode is rated for 66 lumens for 9 hours.
Things I like:
- Crisp bright hotspot
- Impressive throw for its size
- Extension tube included
Things I don’t like:
- Low mode is to bright
- Only 20 seconds turbo mode before step down
