Thrunite Catapult V2
Hy,
a build for a Flashaholic from the netherlands. I should mod the Catapult V2 (XM-L) to XM-L2 and more Current. So a Noctigon XM-L2 U2 1A dedomed was inserted and fired with an LCK 5A Driver. The Driver was potted with Fujik Thermal Glue.
The original Driver was pressed into the pill, so i had to use a lot of force to get it out. The new Driver fits almost perfect. Just solder it to the brass ring.
Some impressions
And some GITD Power on the bezel ring.
I like the flashlight after the mod very much. At the moment it is running with 2x AW IMR 18350 for almost 15 Minutes I think it is useful to mount the extender.
Lux/Candles
The flashlight was measured before the mod at 91 Klux/Kcd with stock driver and dedomed LED. I measured after the modding from 6 metres and calculated back to 1 metre.
Mid: 2060 Lux => 74.160 Lux/Cd (30%)
High: 6020 Lux => 216.720 Lux/Cd (100%)
Now its a real Thrower!
Beamshots
- AndiFire HD2010 ~125 Klux/Kcd
- Thrunite Catapult V2 ~216 KLux/Kcd
- Tiablo A9 Collimatorhead ~155 KLux/Kcd
Distance is about 280 metres, Nikon P100, f=4,5, 3 Sec, ISO800
Controlshot
AndiFire HD2010 (XM-L U2 dedomed)
Thurnite Catapult V2 (XM-L2 U2 1A dedomed)
Tiablo A9 Collimatorhead (XP-G2 R5 2B dedomed)
Another perspective
Tiablo A9 Collimatorhead (XP-G2 dedomed)
And one shot just for fun
Greetings
Kenjii
Nice job !
That is a sweet light now!
Nice mod. I liked what you did with the GITD powder.
Nice mod, mad thrower and that GITD power is so well applied!
Just so you know Fujik is nothing special at all, it is as worst as the worst thermal grease, but well it glues.
Nice job, especially on the GITD bezel.
How did you get it on so perfectly without making a mess?
I miss my Catapult v1. :frowning:
Good job on the mod. From what I remember, these things are built like a tank! Well, more like a mace if you felt like swinging the thing around. :slight_smile:
Hy,
thanks a lot. I am very sad, that this one is not mine ...
The GITD Powder comes from Kilabitzzz: http://stores.ebay.de/glowinthedarkshop/
I mix the powder with UV Glue from my wife which she uses for french nails. So you have enough time to apply the mix to the flashlight as it doesn´t harden on the air. It hardens only under UV light. I applied the glue with a needle. Took about 20 minutes. The glue is pretty comfortable to apply as it has a good surface tension. So you can fill up and press it into the corners with the needle.
Sure, Fujik is nothing special, but it is cheap and plenty for the price and at least non conductive.
Greetings
Kenjii
Very nice, thanks again for sharing.
I’ll have to try the UV glue and GITD powder mixture sometime. :slight_smile:
Glowinc has the brightest GITD powder IIRC
+1
Can you share the info on that nail glue you used? Brand etc, or even a pic. did the GITD diminish or remained the same after application? I heard that some glues affect the ingredients but on the other hand I think this might be easier to take off than regular transparent epoxy…
Thanks for the link Alex. I’d also like to know more about the UV glue. :slight_smile:
Hy,
i used Fing´rs UV Gel clear. Here a link to Amazon Germany: http://www.amazon.de/Fing%60rs-Gel-System-2380-Clear/dp/B003UAQBPU
The Gel becomes almost white after mixing with the GITD Powder but it is still very bright. I havn´t compared the pure Powder to the mix.
Here you can see it on my Blue Star (109-LED Head)
And X-Perimentalthrower
Greetings
Kenjii
Thanks for the link, will be nice to see your other flashlights beam shots :smiley:
it throw fairly well and i like the looks of V2. and nice collection you have there. X-Perimentalthrower looks very special and unique almost to the military looks territory.
Beautiful lights!
I’ll just have to decide between tritium and GITD.
Hy,
i got mine today and did the same mod again The Pill from the V3 is a bit deeper, so the LED is not perfect in focus, as the V2. I will add a spacer afterwards. So in the moment the light has only about 160 KLux/Kcd.
And green GITD Powder
I love this flashlight!
Greetings
Kenjii
Thank you for the info and beamshots Kenjii, waiting for you to show us your other custom lights :beer:
What kind of UV light do you use to cure the glue, LED or fluorescent? What wavelenght UV does the glue need to cure? How long is the cure time?
Thanks! :slight_smile:
Hy,
i don´t know what kind of UV Light that is. It is a box where you can put in your complete hand to cure the glue on the fingernails. But it is fluorescent.
Other custom lights are for example the Trustfire T90-2 (~825 Kcd) or my Blue Star (~981 Kcd) J) The other mods are mostly only driver or LED swaps (e.g. MTE H6-1 XP-G2@3A, Tiablo A9 Collimator 2014 XP-G2@3-4A etc.). Nothing really special. But there is more to come soon :wink:
Greetings
Kenjii
