Thrunite Lynx - scorpion turbohead
*1
Yes, it really does, i haven’t bothered with the standard v2 head since i got the turbo head, plenty of spill and better visuals at distance.
*2
No, not just the switch, the lynx has a full metal switch now and the v2 has a plastic one which makes the lynx alot more durable, i’ve replaced 1 v2 switch after i dropped mine and broke it and i doubt that will happen with the lynx, the lynx is programable with it’s lumens output also on 3 setting from 0.4lm to 1000lm and the lynx uses a buck boost driver that will give you the same voltage to the LED no matter what the battery voltage is so it gives a constant brightness instead of a diminishing light output when voltage drops.
*3
It’s kind of a good thing if you think about it, but it can be a, “put up with it” thing for some, But it does stop the FL from accidental turn on.
Here a BLF look at review
