Another wee pocket rocket build using up some spare parts I had.
This light has been sitting empty for a year or two so I thought I would give it a bit of a revamp.
XHP50 J4 3C on 10mm SinkPad
QTC Pill variable output
ARC glass
OP reflector
Aluminium & brass heat sink
Magnetic tail
Green 6mm x 1.5mm tritium vial
Twisty switch
Black aesthetics
Length 69mm
Width 14mm
Weight 27gm with cells
2 x 10250 compatible
Max - 1600lm - 1400lm @ 30 sec (Very Hot)
Here you can see the 4mm QTC pill in the tail. The magnet holds this in place.
Along side it is a 0.2mm copper plate which sits below the level of the QTC, this allows direct drive when the head is tightened to a certain point, around 800lm.
The aluminium pill has a solid chunk of aluminium press fitted in with a solid brass positive contact.
The reflector is potted to the MCPCB with JBWeld covering the wire connections so if it does desolder itself the wires won't go anywhere nasty ;)
