ThruNite TN36 UT (CW)
http://www.thrunite.com/thrunite-tn36-ut-cw/
Product Description
Features:
- Compact flood flashlight with high quality beam from orange peel reflector.
- Cree Xhp70 technology gives great light efficiency.
- Advanced electronic switch with low voltage indication for silent operation.
- ThruNite ITC (intelligent temperature control) technology to prevent possible light damage from overheating.
- Six modes: firefly, low, medium, high, turbo and strobe.
- Reversed polarity protection system prevents damage to the light.
- Ultra clear tempered glass lens with anti-reflective coating.
- Aircraft grade aluminum body structure with knurling for firm grip.
- Premium type III hard anodized anti-abrasive finish.
- Memory function to set any mode(except for firefly, turbo and strobe) for immediate use.
- Only applicable for 18650 batteries to use.
Specifications:
- LED: Xhp70 with a lifespan of 20+ years of run time.
- Runs on: 4 x 18650 (ThruNite 18650 3200Mah).
- Working Voltage: 10.5 - 17.5 V.
- Output mode/Runtime*: Strobe(7300 lumens /137 minutes), Turbo(7300 lumens /95 minutes), High(2500 lumens /194 minutes), Medium(850 lumens /587minutes ), Low(130 lumens /54 hrs), Moonlight(2 lumens /33 days).
- Max output of NW is a bit less than that of CW.
- Peak Beam Intensity: 20360cd.
- Max beam distance: 285m.
- Impact resistant: 2 meters.
- Waterproof to IPX-8 Standard (2meters).
- Weight: 397g without battery.
- Dimensions: 135.4 mm in length x 64 mm in diameter.
Accessories: Holster x1 Spare, O ring x2, Battery Carrier x1(inside the flashlight).
Operation:
To Turn On/Off The Light:
Press the side switch to turn the light on/off.
To Change Modes:
When the light is on, long press the side switch to cycle through low, medium and high.
Shortcut to firefly: When the light is off, long press the side switch to get firefly mode.
Double click to turn to turbo from any mode. Another double click to get strobe.
Memory Function: The light will turn on in the last mode accessed, except firefly, turbo and strobe.
ITC Technology: The light will automatically lower the current when temperature in LED or driver rises to 80 degrees centigrade to protect the flashlight from overheating. Thus to extend its lifespan.
Battery Replacement:
Take off the tail cap, insert four 18650 batteries into the battery carrier, put the carrier into the flashlight and screw on the tail cap.
With either end of the battery carrier towards the light head is OK. But make sure the batteries are correctly inserted into the carrier with polarities matched (springs on the carrier should connect with the cathodes of batteries).
Low Voltage Indication: When the indicating light on the switch turns from blue to red, it means the batteries should be replaced or charged.
Warranty:
1. 30 days free replacement. Any defective light will be offered free replacement by our distributors or dealers unconditionally.
2. 24 months free repair. Any product or part which is found to be defective under normal use and service within 24 months counting from the date of purchasing with proof of purchase.
3. Lifetime limited warranty. As to those exceed 24 months of the purchase date, we will still provide with warranty service, but the cost of parts will be charged, and freight should be paid by the customers.
Special Notes:
1. Please choose an authorized distributor or dealer to purchase ThruNite products.
2. Make sure to use ThruNite products properly.
If there is any question during the use of ThruNite products, please be free to contact us by sending an e-mail to service@thrunite.com.
And in store it's $229
Or €205.69
If the Niwalker Minimax Nova MM15 MB is also 7000+ lumens then it’s definitely a better buy than the TN36 UT for its smaller form factor with lesser weight, right? Difference of 200 - 300 lumens don’t make a difference to the eyes at such high lumens.
However, if the TN36 UT performs better in terms of longer time in TURBO mode then it’s a better buy then.
So, just wait for some reviews before buying.
FI, I own the Niwalker MM15 first and then the TN36 later.
