So, I’ve got the Thrunite TN36 and I was thinking if there are any ways to boost performance :bigsmile:
I know Vinh mods these, but as I live in Sweden, that’s not an option.
First step is to replace the MK-Rs with XHP70. But the question is, is it worth it, will I gain anything? And also, can this be done without modifying anything else (MCPCB etc)? Or can I just solder off the MK-Rs and solder on the XHP70s? (I think they have the same footprint but I’m unsure)
Is there anything that can be done with the driver to boost performance? Vinh doesn’t really tell his secrets and I’ve scoured the web but I can’t find any mods.
Sure. Ability to choose a different tint, more lumens, etc. MKR and XHP70 share the same print AFAIK.
[/quote]
[/quote]
It’s an easy mod to boost current. Remove driver, snap picture, and I will point out the sense resistor if you are unable to figure it out. (Too lazy to take mine apart at the moment).
were you able to do the swap in TN36 ? I am also thinking of exchanging MKRs for XHP70s. Since, I am not experienced modder, I would appreciate sharing your experience.
If you do the mod, the user interface work as its supposed to -> Low/Mid/Max/Turbo/Strobe/Moon ?
