This post is a summary of specs of all the important lights in this thread. Please expect numerous revisions because of several additions of more flash lights and more data, repeats of measurement, corrections of errors, etc. I am an amateur using hobbyist-grade equipment, pls set expectations accordingly.
Measurements I repeat measurements many times and make mistakes along the way so please don’t be surprised if you see changes or inconsistencies between posts from different timelines, such as early vs later posts.
Emisar DA1K w/ NTG50 4200k Lume X1 Driver, Green Reflection AR lens
With N261S TIR Throw Optic: (Vs 10394 Wide Optic)
Output 2740 w/ EVE 40PL, 2730 w/ JP40-AM40
OUTPUT at each level: 0-5-36-168-448-926-1744
CCT 4200k @ Turbo
Duv -0.0095 @ Turbo
Throw ANSI 272m CD/LM~11
Fireflylite E07X with FFL351A HI 4000k Rosy Tint Discussion starts HERE
Output: 4330 lm w/ Molicel P45B. Starting from Moonlight: 0-3-57-233-652-1400
Throw- ANSI 30 sec: 269 m with Wurkkos battery, 134 m with Molicel P43B (Molicel much brighter but then gets hot and steps down within 30 seconds, much faster than Wurkkos.)
CCT 3900k Ra 98 R9 92 Duv –0.0091 @ Turbo
Level 2 -0.0122 3744k Level 3 -0.0019 3765k Level 4 -0.0014 3789k
Level 5 -0.0101 3810 Level 6 -0.0101 3832k Turbo -0.0091 3931k
Driver: Lume1 6A High Efficiency Constant-Current Buck Driver (over 90% efficiency) with FET Turbo.
Green reflection AR lens.
Convoy M21H w/ Nichia 219b 4500k Discussion starts HERE and significant effect of TIR optics’s beam angle on rosy tint HERE .
Driver Boost 6V 5A
Output (similar to S21D): ~16-215-605-1600 lumen
Throw:
175m (with 12° stock default)
143m (with 24°)
114m (with 36°)
CCT ~4300k Ra 96 (R9080 per Simon) Ra97 R9 90 w/ LM4 Smart
Lens: AR w/ purple reflection, must ask Simon for the more desirable green reflection
Duv
Purple Reflection AR Lens: Turbo~-0.0060, Turbo-1=-0.0041, T-2=-0.0042, T-3=-0.0043.
Green Reflection AR Lens: Turbo=-0.0076, Turbo-1= -0.0065
Green Lens + 36 degree TIR Turbo=-0.0092
Hank-Emisar D4K w/ 519a 5700k DD: Discussion starts HERE
Driver: Lume X1
Output: 2000 lm Turbo. From moonlight: 0-6-38-121-306-616-1065
Throw ANSI (30 sec): 218 m (longest throw among my quad Nichia lights)
CCT: 4100k
Duv: -0.0075 (Turbo)
Lume X1 40W Boost Driver, Constant Current Regulated (up to 95% efficiency)
Convoy S21D with 219b 4500K Buck 3V 8A constant current driver
CCT 4486 Ra 95.8, Duv –0.0100 hot, –0.0084 cold, (heat drops Duv 12 points)
Output: 1690 w/ 10 Clear, 1980 w/ 30 Bead (Confirmed: Strange – Higher w/ Bead than w/ Clear TIR. Whereas Carclo for D4V2 higher with 10622 Clear TIR than with 10623 Frosted TIR.)
Output depends on battery - Mode 100%-35%-10%-1%-0.1%
30 Bead Molicel P45B: 2100-1570-530-55-10
30 Bead Littokala: 1850-1570-530-55-10
Throw:
170m (with 10° Clear)
157 (10° Bead)
144 (30° Bead)
113 (60° Bead)
Lens for S21D Multiple TIR choices: 60° Bead, 30 Bead, 10 Bead, 10 Clear (available from Simon, or possibly as gift at time of purchase). 60° and 30 Bead has best tint. See comparison and beamshot discussion HERE
Driver
S21D: 8A Buck (first release, like mine, >90% efficiency - more than FET) or 12A FET (the batch sold in June of 2022)
S21F: Max output 8A, buck constant current.
219b 4500K in Emisar D4V2:
Output: 1670 lm w/ 10622 (Stock)
Throw: Carlo 10621 Clear 140 m, Carlo 10622 Clear 137 m
CCT 4559 Ra 95.7 Duv –0.0087
219b 4500K in H2 Headlamp:
Output: 596 lm
CCT 4775 Ra 95.2 Duv –0.0135 (cold Turbo) to -0.0160 (hot Turbo)
219b 3500K in Emisar D4V2:
CCT 3491 Ra 96.6 Duv –0.0045
219b 3500K in H2 Headlamp:
Output: 495 lm
CCT 3484 Ra 95.5 x 0.4001, y 0.3732 Duv –0.0067
219b 2700K in Emisar D4V2:
CCT 2710 Ra 97.6 Duv –0.0022
Output: 1350 lm
519a 4500k in Skilhunt H04R RC Headlamp
Output 682 lm
Throw: 84 m
CCT 4200k Ra=96 R-red=84 Duv 0.0000
519a 4500K in Convoy S21D (LED damaged, don’t trust these numbers):
Output: 1900 lm
Throw 157 m with 10° Clear TIR
CCT 4100 20% Brightness (increases about 150 points from 1% to 100% brightness, example 3743 to 3904), Ra 97.6, Duv –0.0010 cold, –0.0027 hot (heat drops Duv about 20 points).
B35AM 4500k in Convoy M21B:
Output 1090 lm
Throw 263 m
CCT 4348 Ra 98.2 Duv –0.0050 35% brightness, –0.0036 0.1% brightness (with 2nd Opple)
9. E21a in Emisar D4V2
CCT 4908 Ra 97.4 Duv -0.0077
Output 877 lm 11/2024 (previously reported 1520 lm - not sure if I’ve made an error there)
Throw (error??):
Carclo 10623 Frosted 111 m (frosted optic makes “hotspot” of D4V2 w/ E21a very dim), repeat 2024 only 100 m
Carclo 10622 Clear 170 m
519a 2700k & 5700k in Convoy S21F Discussion starts around HERE
Important Note: I got two S21F’s: the first light belongs to the first batch that was released, and has 5000k and 2600k 519a, the second light belongs to second batch had 5700k and 2600k 519a.
Ra ~98 all CCT’s
Various CCT’s at Level 4
2600k (2 LEDs): Output 1130 lm, Duv –0.0010, no PWM (2nd light Duv -0.0002)
3000k (4 LEDs): Output 1180 lm
3300k (4 LEDs): Output 980 lm
3700k (4 LEDs): Output 900 lm, Duv –0.0072
4500k (4 LEDs): Output 1350 lm, Duv –0.0055 (2nd light -0.0075 output=1100)
5000k (2 LEDs 1st light): Output 1370 lm, Duv –0.0048, no PWM
5000k (4 LEDs 2nd light): Duv -0.0060 Output 1360 lm
5700k (2 LEDs 2nd light) Duv -0.0036/-0.0055 5000k (2nd measurement)
All CCT mixings that use 4 LEDs have PWM
Fixed 3600k CCT at Level 5 aka true Turbo, true 100%, etc.
4 LEDs, no PWM
Output 2050 lm, Duv –0.0071 (2nd light CCT 3800k Duv -0.0093)
S21E with Nichia B35AM 4500k:
Output: 1000 lm (6v, 2.2A) measured w/ Texas Ace lumen tube
CCT 4300k CRI 97
Turbo Duv -0.0050 (c/w Simon’s number)
S21E with Nichia 519a 4500k:
Output: 3-23-70-145-300-525-800-1200 lm (3v, 6A)
CCT: 4500k CRI 97
Duv: Turbo=-0.0025, T-1=0.0000
Don’ t use with high current battery - LED color turns whitish
Specs from Simon:
Nichia 219b 4500k
2000LM (LED size 1.5 mm)
CCT 4526k
Ra 96
R9 97
R12 79
Duv –0.00995
Nichia 519a 4500k
2600LM (LED size 2mm)
CCT 4500k
Ra 93.6
R9 82
R12 80
Duv 0.00091
Nichia B35AM 4500k
CCT 4454k
Ra 98
R9 99
R12 77
Duv –0.00503
Some other numbers posted by Simon in past here:
CRI for 219b 3500K sw35
CCT 3583K, Duv –0.00392
Ra 95.7, R9 82
CRI for 219b 3000K sw30
CCT 3027K, Duv –0.00535
Ra 96.6 R9 84
External Temperature after 25 minute run-down from Turbo/Max brightness level, measured with IR gun pointing at the head area. Note that this is laying on plastic in a room without any cooling.
Convoy S21D —-> greater than 60° C
Convoy M21B —-> 59° C
Emisar D4V2 219b 4500k (with max thermal limit set to 55 C) —-> 49° C
Olight M2R Pro —->47° C
Sofirn SP36 BLF 4000k —->45° C
Convoy M21B w/ B35AM 4500k —->42° C
EDIT 2025: Convoy S21D supposedly has temperature regulation set to Tmax 55 C, but it is faulty and cause light to get to hot in high brightness mode. Especially for Turbo, you must watch temp and turn down brightness if it gets too hot. Temp regulation in my other Convoys works fine. Emisar D4V2 also has temp regulation. The factory setting for upper thermal limit is 45 C, but I changed it in all my D4V2’s to 55 C.
