Let’s say I were to make a briefcase sized battery bank with a safe voltage cutoff, how would you go about doing this? What cells would you use?
I have no idea how to make this easy to charge (other than taking out each battery and charging), and how to build in a protection circuit (vs using protected cells).
What I’ve been seeing people doing in another forum is that they were connecting all the cells in parallel to eliminate charging imbalances and them using a boost driver to increase the voltage to a desired output. Not too efficient though…
