I needed something to do while waiting for my 3-up XP-G2 to arrive so I thought I’d try a TIR P60.
I ordered a few Carlco 26.5mm optics from ledsupply, plain tight, narrow and wide frosted and elliptical along with a few lens holders. I had a S/F 4.2-8.4V XM-L with a dead driver so I tossed the driver and removed the XM-L from the pill. By the way, E1320s advice about putting the pill in the freezer worked like a charm!
After filing the lip off the top of the pill I cut a 7mm piece of 3/4” copper rod, squared and lapped the rod and used AA to attach it to the pill.
I slipped the pill into a 10-12mm piece of 3/4” copper pipe and soldered it together (really more like sweat it all together) with a torch. I set the pipe flush with the top of the copper rod and covering most of the brass pill. Attached the XM-L and a KD V2 8 7135 driver with one extra chip installed.
With no spring and just one layer of tin foil it fits very snug in my L2m.
Now on to the optics. I messed around with the 20mm Carlcos quite a bit last winter in Match-mods and really liked the ease of swaping them out. I never tried using a lens holder with them because there just isn’t much room in a Mini-Mag head. I noticed that when in the holder these TIRs sit just above the base of the LED as opposed to sitting down over the base on the star. I decided to use the holder but to do so the top of the holder has to be cut off to fit in the head and the 4 posts at the base have to be filed/sanded down to fit in the body.
And here’s the end result.
I compared the plain tight lens with and without the lens holder and the hot spot is both tighter and more defined with the holder in place.
The light pulls 3.3A at the tailcap and the body gets nice and toasty in short order on high. I like the fact that changing optics is as simple as removing and reinstalling the head, and the pill is so tight that the head can be installed without any optic for an XM-L mule.
Now I wish those XP-G2s would show up.
