TN30 Modes Not Working...
Hi all, I’m hoping someone else has had this issue either with a TN31 or a TN30. On my TN31 I did the usual bridging of the sense resistors and de-dome plus beefing up soldering joints and braiding springs etc. Anyway, I was told that these mods also work the same for the TN30, so I have done the same mods, put it all back together and it works, but it just seems to be on high all the time. The mode selector ring won’t change modes anymore. I thought maybe it was the reflector shorting against the negative lead but it still won’t change modes even with the reflector taken out. Any ideas what would cause this??
Cheers,
Tim
That's not uncommon behavior when completely bridging sense resistors, lots of lights do that.
Did you check that the magnet and ball are still in the selector ring? Is the selector ring in the right position? Can you undo the resistance mod and check if it fixes it?
I think its shorted FET that used to dimming.
I believe I have heard of something similar happening to folks and they found they put the driver back in the wrong position. I think I recall when I worked on mine there are 3 screws and that it's possible to put the drive in a different orientation.
The selector ring is in correctly. When selecting standby it goes off and when selecting strobe it goes on to strobe. The ball still hits the indents in the body as normal.
I did double check the driver was in the correct way. There is a large section of contact pad on the driver which needs to line up with the bare metal shelf in the body of the light, and it does.
The only way I could undo the sense resistor mod would be to buy more sense resistors. I have been told to maybe try a 050 one?
Uh oh, unfortunately it seems like the driver isn’t as simple as bridging the resistors like the K40/TN31.
Did you misplace the original resistors?
Haha you could say I “misplaced” them… Really though I just threw them straight into the bin.
I did speak to Vinh before doing this mod as you well know I had concerns prior and he said he has done plenty of them with bridged sense resistors and has never had this issue with any of them.
Ok coming back to this again. Where can I buy sense resistors? I assume I need 0805 sized? I want to try R050s which I believe are 0.05 ohm? All I can find though are higher than that.
Being down there probably cutter.
You need to find the highest power resistors you can (keep I mind 0805’s dont come too high of power) but you’ll definitely want 1/2W (they also come in 1/4 and maybe 1/5W). There’s 100’s of choices for .05ohm 0805’s but probably only one or two in 1/2w.
Two of these will equal .05 ohms. They are larger (1206 size). So they well handle more wattage. Also, 2 will split the load between each other.
