Top contact of 21700 getting pushed in
I am finding that the top contact of 21700 cells gets pushed in when using with a Convoy S21e. Is there any way to avoid this? See picture.
Start measuring cell lengths and check the listed lengths. Learn the max in your lights, so get very tight in girth also.
What brand of cell is this? Also is it protected?
I have never seen any of my batteries get this badly dented in my S21E
I have had that happen in an M1 with the supplied cell, but it was dropped from 3’ or so.
It’s not protected. 7.06cm long.
Strange, I’ve used that cell before but never had that issue
I’ve got quite a few 18650s with some good dents and at least two 21700s and I think two 18350s with dents in the tail. The tail dents are from the convoy s6 with a short tube.
These are all from drops.
Some lights have very stiff front springs.
The convoy M21H still uses a front post.
I’ve been thinking about ways to reduce the dents for a while and about a week ago I started experimenting.
I have some larger o-rings with different cross sections. 1/8 inch and 3/16 inch. I was going to try to find some locally in those thicknesses with the right diameter but no success. I’m sure I could find them online with different cross sections.
I decided to start cutting up the larger ones and placing them down in the tubes on the front end to see what worked.
The 1/8 inch cross section seems to be just the right thickness on a few lights that I’ve tried it on.
Convoy M21H, S21E
Armytek wizard C2 pro, and pro max.
However on the s21e it only works because I shaved the o-ring down a little tiny bit with a sharp knife. So that one needs a slightly smaller cross section. Especially if you’re going to try to put a dented top back in there.
The positive end still makes contact with the spring or post but it can’t travel much. That doesn’t allow much pressure on the flat top. That should prevent any further or future dents in new batteries.
I don’t think I can do anything with the S6 because both springs are really compressed with that short tube. While test fitting I used a bic stick pen to push them down into place and I made a little bent piece of number 14 copper wire for fishing things back out when I needed to during the testing.
One of these pictures is looking down through the tube with a cut o-ring in place in the pro max head. The reflection off of the wall makes it look like there are two o-rings.
These batteries were never designed to be manhandled and have a lot of pressure put on these flat tops especially from a post or very small spring concentrated in the very center of the flat top.
When dropped this o-ring will take almost all of the force.
My previous EDC which was the lumintop fw1a used to dent the flat tops also. That one would require a very thin o-ring because it is very little travel on that short stiff spring.
I will be looking at some more lights that I use on a regular basis.
The mcpcb on some lights may have components out near the edges where this is not going to be a good way to do things.
I went to add some more o-rings to some additional lights.
The Lumintop fw1a and the fw3a will not accept them due to components and the way the inner sleeve needs to make contact.
The convoy s21e driver with Anduril has a much longer spring so an o-ring with a 1/8 inch cross section works good.
The s21e with the constant current driver needs a cross-section that’s just a hair smaller. So are you going to have to shave a 1/8 in o-ring or maybe there’s a metric one that would work okay.
Hi Oli, i have a doubt about this: doesn’t it somehow diminish the waterproofing of the light?
I have here a tail switch PCB with the spring soldered on and while yesterday on a call, I was fiddling with it, doing the only thing I could do: compressing the spring.
I noticed that bottoming it out it became shorter after a few times. As in 11.5 mm on a new switch assembly vs 9.5 mm of the PCB of which I compressed the coils repeatedly.
Now, would doing the same in both springs, tail and driver, be a solution that doesn’t change the waterproofing?
I am not removing or replacing o-rings. The same o-rings that were already on the tubes are still in place. This o-ring is put in after the tube is already screwed into the head.
The o-ring is just there to limit how far the front spring can compress if the light is dropped on its head due to the weight of the battery. It doesn’t change anything else.
I’ll add a few tips and tricks while trying to determine the right thickness.
You do want to have a little bit of battery movement if you’re pressing on the tail end of the battery.
And it’s easy enough to use a piece of wire between the negative end of the battery and the edge of the battery tube and then try to operate the light. If it takes a lot of pressure pushing down on the battery to make contact with the spring then the o-ring is too thick.
Honestly, I think some flashlights are just a bit harder on batteries than others. I’ve got a few cells with small dents on the top from regular use. They still work fine, but it’s definitely something I check when charging.
