This is a mod that I've been wanting to do for a while. I wasn't sure if it would work, but after asking my fellow BLFers a lot of dumb questions, I was hot to trot.
The J12 host is pretty small, but it arrived the day I decided to do this build, and it looked like an MT-G2 would fit in the center emitter hole.
I used a BLF17DD FET driver from RMM with a Zener mod. My copper clad circuit board came in handy for shaping a contact board that everything would be mounted on.
Right after I took those pictures, I realized I had meant to have the battery+ go directly to the LEDs, so I had to tear it apart. It's not as pretty now, but it works.
Since the reflector would be sitting directly on the MT-G2 substrate it would be a little higher than where it should sit on the XM-L2s. Since this was just a prototype, I didn't want to get into all kinds of technical mounting logistics, so I used Sinkpads which are a tiny bit thicker. In the end, it worked well enough.
Three parallel leads from the driver with 2 x 2 series XM-L2 and 1 x MT-G2.
What was bothering me, was the thin film that covers The MTGs substrate and prevents shorting was peeling off. Even after this pic was taken, it had all fallen of, leaving fully exposed +— pads on the top.
This emitter came out of my very first MTG TorchLite build. The host that started the MTG craze on BLF. That was before Noctigons, and it was on an aluminum MCPCB with a 5A driver. I wonder if that caused the the protective film to fall off
I put Klapton tape around the reflector hole and hoped it would not short out.
it seemed to work. Yea!
I hot wired everything with magnets and alligator clips to get a few measurements before I tucked it back together.
Mt-G2 on high at the emitter.
XM-L2 at the emitter.
Anyway it works. It's daylight out so it needs to wait. I'm really tired, and my cat hates me. I just wanted to get this light built.
I thought the current readings would be a little higher, but I guess thats a lot of emitters for two cells.
I tried to take a wall shot, but my ipad camera ignores all the periferal light and condenses it all into a hot spot. It's really bright.
I'll see if I can do better outside at night.
I'm not sure, but this may be the first MT-G2/XM/L2 hybrid light. It was a fun project.
No. I'm retiring after the OL build is finished.
