I’m researching components and was wondering what the different channels would be used for in a driver like the Dr Jones H17F Driver w/ lucidrv2 - 7135 + FET
(found here 17mm DrJones H17Fx Driver w/ lucidrv2 - 7135 + FET)
Also, can you explain what FET is and why/how is it used?
An fet is basically a switch. When it sees a voltage at its gate pin it closes the switch and allows the current to flow from its source pins to the drain pin allowing the led to be lit up. The signal to the gate pin can be pulsed on/off very quickly and this creates dimming.
7135 is very similar except it limits the amount of current from its source to drain pin to 350ma. It can be pulsed to atchieve lower levels as well.
The triple channel drivers you hear about usually have a configuration similar to this:
Channel 1- one 7135
Channel 2- six 7135
Channel 3- fet
When the fet channel is used 100% it is considered max possible brightness. It is essentially equal to direct drive meaning the led is connected straight to the battery. The led will take whatever the fet will give it.
The reason three channels is used instead of one fet channel that is pulsed is mainly because it is more efficient. The driver uses a combination of these channels to best match efficiency and output level. A very low moon level is most efficient using one 7135 with a low pulse width modulation percentage. Middle modes for channel two and fet for turbo.
This is a very basic description but is a start for you.
