I like triples, don’t know why but find I gravitate towards them when I find the time to mod lights. I also found, after putting together a single XM-L2 S4 that I like the Convoy S series lights. So when I saw Richard’s (Mountain Electronics) S3 triple XP-G2 I had to build one.
I started with an S6 host, triple XP-G2 3C Notigon, Carlco 10507, Q-Lite and 3/4” copper rod.
Set up the driver with 8 more 7135s at the default 3 modes. Pic is before wire modding the spring. By the way, I know most folks seem to use copper braid but I’ve found using wire is easier.
Next up was the heat sink, 3/4” copper rod. Cut to what I thought at the moment was the correct length, square up the cuts, drill the hole through the middle, file the end to fit the S6 brass pill and start lapping the ends.
The problem was that just after making all my critical measurements and jotting crude notes I took my daughter to her soccer game. When I got home I was determined to get this light done, ran downstairs and cut my copper, proceeded to drill, file sand and photograph, then it hit me. I cut the copper to the total length of the original reflector, no consideration of the room I’d need for the MBPCB, and optics.
Ok, check the notes, cut 11mm off the sink and keep going, gotta have this light in my hand tonight. Here’s the sink attached to the pill prior to final lapping.
And with the MBPCB and optic.
Nothing left but to put it all together.
I have to say I’m amazed at the output. Until now my brightest triple was an XP-G2 at 5.02 tail-cap amps in a Solar-Force L2P with an A001 head. That light was built just after the XP-G2 came out and before copper MBPCBs were available, but the copper heat sink is larger. The S6 with a smaller heat sink but better thermal path shows 5.85 at the tail cap and blows the doors off the SF in a side by side comparison, both running Samsung INR18650s.
Many thanks to Richard for putting me onto this combination.
