After a decade of owning various tail-switch Convoy lights and performing countless mods, major and minor, I’ve encountered pretty much every bug I can imagine to have plagued a tail-switch Convoy light. Some of them occasionally occur in stock form, while others are discovered (or introduced!) during a mod.
Finding myself giving the same answers to the same troubleshooting queries here and on reddit, I’ve decided to write up this guide to hopefully save both Simon and his fans some time. If you have:
- an entry to submit,
- additional information/tips regarding the existing issues,
- technical corrections or better writeups,
- images that might clarify some of the issues,
please let me know!
The guide will be ordered by flashlight part, starting from the tail. Each entry describes a problem, possible observed symptoms, an explanation, and my recommended solution. A diagnostic image is provided if available. Indexing by symptom seems more natural, but impractical because many different problems can cause similar symptoms. The reader of this guide thus needs to have a rough idea of which part of the light might have gone wrong, to start looking for relevant entries.
Needless to say, this guide may also be helpful outside the scope of Convoy tailswitch lights, as many problems described are universally applicable to all lights.
Part 1: tailswitch
Mushy-feeling, or yellow-looking silicone button
Symptom: self-explanatory.
Explanation: Over time, the silicone ages, turning yellow and sometimes losing elasticity. Alternatively, even a fresh button may feel mushy if there is a gap between the actual plastic switch and the silicone button.
Solution: replace silicone button, or superglue a spacer onto the plastic switch button to close the gap.
Lighted switch interferes with driver function
Symptom: driver UI failing to work as intended, erratic behavior.
Explanation: colors such as red and orange have very low forward voltage, and end up drawing too much current, enough to mess with the driver.
Solution: choose a switch color with higher Vf (blue, pink, purple, white) to reduce current consumption. If you must keep the existing switch/color, replace the resistors with higher values if you are able, or break off one of the LEDs if you are ok with asymmetry.
Switch PCB too wide to fit into backside of retaining ring, preventing contact
Symptom: difficulty tightening retaining ring, flashlight fails to turn on.
Explanation: the switch PCB’s outer trace must contact the back surface of the retaining ring to establish connection. Some batches of switch PCBs are mismatched to some batches of retaining rings; alternatively, the break-off tab did not work cleanly.
Solution: use sandpaper to reduce the diameter of the fiberglass PCB.
Cracked/broken clear washer
Symptom: retaining ring getting very loose on its own, intermittent contact, flickering, weird artifacts in the lit tailswitch.
Explanation: the stock clear washer is weak, and would break over time if the retaining ring is very tight.
Solution: avoid over-tightening the retaining ring, and avoid using long batteries (e.g., protected cells), which exert too much backward pressure.
Loose retaining ring
Symptom: intermittent contact, flickering, or light failing to turn on.
Explanation: the retaining ring is too loose, to such an extent that the battery pressure pushes the switch PCB backwards and breaks contact with the retaining ring.
Solution: Tighten retaining ring. Note that the retaining ring is reverse-threaded in some models, requiring counterclockwise turning to tighten.
Part 2: battery tube and threads
Threads and contacts clogged by gunk
Symptom: intermittent/poor connection, turbo not as bright as usual.
Explanation: the bare parts of the battery tube have accumulated enough grease-dust mixture to obstruct electrical conduction.
Solution: clean all threads on the battery tube and head+tail. Toothpick could be helpful to remove dirt from thread grooves. Also wipe the flat aluminum ring inside the tailcap just outside the retaining ring; this flat Al ring is the electrical contact to the battery tube.
Reversed battery tube
Symptom: light failing to turn on.
Explanation: the driver/head size of the battery tube needs to be bare aluminum to conduct electricity.
Solution: ensure the bare aluminum threads are facing the head, and the anodized end is facing the tail.
Battery tube doesn't fit
Explanation: some lights (e.g., S2+) have gone through different batches with different threads. Older S2+ have triangular/trapezoidal threads, while the newer version has rectangular threads. If you have lights/parts from different batches, they may not be compatible.
Part 3: driver and pill/shelf
Difficulty opening retaining ring
Explanation: sometimes the retaining ring is unlubricated and over-tightened out of the factory.
Solution: make sure you have the proper tool: needle-nose pliers. Then try the following in any order/combination to taste:
- WD40 or other lubricant
- Wrapping the pill or affected part in rubber bands to improve grip
- Thermal shock, alternating between freezer and candle flame. Try to not burn components on the driver–the spring may deform from the heat.
Driver trace too narrow to contact adaptor ring
Symptom: light failing to turn on, or intermittent/poor connection
Explanation: if you’re using, say, a 17mm driver with an adaptor ring in a light designed for a 22mm driver, the driver’s trace might not have enough area to make contact with the adaptor ring, which is part of the circuit.
Solution: go to the head-facing side of the driver (i.e., the end without a spring), and coat a few points of the outer trace in a thin layer of solder. This improves contact with the adaptor ring.
Driver has large component that doesn't fit inside retaining ring
Symptom: the inductors in buck/boost drivers and the 7135 chips in linear drivers may fail to fit in the inner diameter of the retaining ring.
Solution: get this special thin retaining ring from Convoy, which has enough clearance to fit around the driver’s components.
Non-chamfered holes damaging wire insulation
Symptom: general failure.
Explanation: the driver wire holes on the pill/shelf are sometimes very sharp and can cut through the silicone insulation on the wire, causing a short.
Solution: use a crappy knife to ream the wire holes. Brass and aluminum are both very soft and easily carved by steel.
Part 4: LED and MCPCB
Large solder blob messing with centering gasket
Symptom: large visible blob of solder on the LED’s side. [Source]
Explanation: an unclean reflow.
Solution: use a hobby knife to cut the blob off. Solder is a very soft metal and is easily cut by steel.
Only half of a quad-die LED lights up
Symptom: 2 of the 4 dies light up, while the other half remains dark.
Explanation: the LED was not reflowed properly, with a layer of rosin flux insulating one of the electrical pads.
Solution: redo the reflow, gently tapping the emitter to break the layer.
LED only turns on turbo and loses other modes
Symptom: the light only turns on turbo, and does not respond to mode changes.
Explanation: the most likely explanation is that the LED was poorly reflowed, with one of the electrical pads making contact with the thermal pad, which is connected to the flashlight body and bypasses the driver.
Solution: redo the reflow, and use multimeter (continuity mode) to ensure that neither electrical pad is connected to the thermal pad, equivalently, the bare copper underside of the MCPCB.
LED turning blue on turbo
Symptom: the light becomes increasingly blue with higher modes, possibly turning blue-green and dimming on maximum.
Explanation: the LED was overdriven or poorly heatsinked. The phosphor is unable to handle the power density and reaches saturation.
Solution: If the LED is not damaged, check thermal paste and switch to a lower-power driver. Otherwise, get a new LED.
Hotspot center is brown/yellow/green
Symptom: the hotspot is white around the outside but has large discolored patch at the center. [Source]
Explanation: the LED’s phosphor was deposited unevenly, with yellow-green phosphor concentrated close to the middle. Frequent issue with earlier SFT25R 5000K batches, as well as some FC40’s and other random emitters.
Solution: chances are that most LEDs in the same batch have the same issue. Wait for a different batch or switch to a different LED altogether.
If you don’t mind losing throw, use a diffusive TIR optic or diffusion film to smooth out the discoloration–an OP reflector likely isn’t enough.
Dirt or flux contamination on LED surface
Symptom: there is visible dust, or brown spots, on the surface of the LED.
Explanation: during reflow, the flux in the solder may spatter onto the LED surface.
Solution: for dust particles not stuck to the surface, use clear silicone “nanotape” to gently remove it. This type of tape is a solid homogeneous substance, which removes dust but does not leave behind any residue.
For solder flux spatter (brown spots), gently place a tiny drop of isopropyl alcohol onto the spot to dissolve it, then wick it up with q-tip or kitchen napkin. If latter, choose a type that doesn’t shed fibers.
Part 5: gasket, reflector/optic, and beam
Asymmetric beam with lopsided hotspot/corona
Symptom: the hotspot and corona are visibly lopsided. [Source]
Explanation: the centering gasket is not doing its job. Many round gaskets have holes that are wider than the emitter’s diagonal, thus allowing the emitter to move around freely.
Solution: switch to a gasket with a square-shaped hole. Though some recent batches of square-hole gaskets are themselves asymmetric, which cannot be fixed. The butterfly-type 3535 and 5050 gaskets have consistently good quality.
Alternatively, some TIR lenses come with a centering mechanism, so you may consider swapping a reflector for a TIR instead. In particular, the 20mm narrow-angle S2+ TIRs produce much better throwy beams than the stock smooth reflector.
Poor beam focus: hotspot diverges right away or makes an X shape
Symptom: the beam’s hotspot does not look parallel, but rather diverges like a cone very quickly, or converging to a point and then diverging quickly. [Source for X-shaped beam]
Explanation: the LED’s location is too far from the focal point of the reflector. There is a mismatch between the LED height, gasket thickness, and reflector thickness.
Solution: the gasket needs to be lowered by sanding the bottom, or raised by padding the bottom with tape. Plastic glow-in-the-dark tape is the best candidate, being rigid, heat-resistant, and thick enough that a single layer can make a difference.
If the beam diverges right away, lower the gasket by sanding. If the beam makes an X, i.e., converging and then diverging, raise the gasket with tape. Do a bit at a time, checking the beam on a faraway target each time to avoid going overboard.
Dark hole in the middle of the hotspot
Symptom: the beam’s hotspot is mostly ok, but with a tiny dark center when white-wall hunting at a far distance. [Source1][Source2]
Explanation: for various reasons, the LED’s very center is darker than the surface average. This can happen due to randomness in phosphor deposition (e.g., 519A), or due to a gap in the quad-die structure (e.g., SFT70, B35AM).
Solution: if using a smooth reflector, slightly tweak the focus by adjusting gasket thickness (see the previous issue). Going with a sub-optimal focus can introduce enough blur to smooth out the spot. Swapping to OP reflector is a better solution if using a floody emitter.
Alternatively, if the spot is very bad as in the second example, swap to diffuse (beaded/matte) TIR is a must.
Angular tint shift: yellow-green hotspot, pink-purple spill
Symptom: the beam is not homogeneous in color. The hotspot/corona is warmer and greener, while the spill is cooler or pinker. [Source]
Explanation: LEDs emit different colors at different angles, so a non-mixing optic (like a reflector) preserves these angular differences in the beam.
Solution: choose a domeless (flat) LED whenever possible. If you must stick with a domed LED, choose a TIR optic, which mixes light much better than a reflector.
Super ringy beam
Symptom: bright thin rings in the beam, most often seen at the outer corona or in the spill.
Explanation: there are unwanted reflections within the optical assembly.
Solution: turn the light on moon, shine it on a wall, and go to the ringy place and look back into the reflector to identify which part is generating the rings. The solution depends on where the rings are coming from.
A common source of rings is the bottom-most part of the reflector, which is lit by the LED’s sideways emission and projects a ring around the corona. In this case, choose a gasket with a tall rim, or pad the gasket from under. Or try a different LED, which might play nicer with the setup.
If you don’t mind losing throw, swapping to an OP reflector is a sure-fire way of smoothing out the rings.
If the rings are coming from a shiny stainless steel bezel, there’s little to do than to color it black, sand it matte, or swap out the bezel.
If the light has a non-AR-coated glass, swapping to AR can eliminate some rings.
Deformed reflector producing unfocusable beam
Symptom: the beam does not focus properly even with gasket adjustments. The hotspot may be excessively divergent or misshapen.
Explanation: some batches of reflectors are worse than others, and some reflectors (e.g., S2+ smooth reflector) are consistently deformed. A certain L21B batch is the most famous example.
Solution: whenever there is a choice in reflector bottom opening, always choose the larger. That means 9mm for C8+/M21A, and 11mm for L21A/B. For unclear reasons, the narrow-opening variants are much more likely to be deformed.
For compact lights: choose S6 for a reflector thrower, or use a narrow-angle TIR in an S2+ to out-throw the stock reflector.
Reflector contaminated by dust or fingerprints
Solution: if the contamination is minor, don’t try to clean it. Stray dust carried by air would fall in and make it worse; plus, any sort of rubbing or solvent application damages the reflective surface.
If the contamination is significant or mobile (threatens to fall onto the LED and burn up), use clear silicone “nanotape” mounted on a toothpick to gently remove it. This type of tape is a solid homogeneous substance, which removes dust but does not leave behind any residue.
Part 6: glass window and bezel
Difficulty removing bezel
Symptom: the bezel is stuck and would not come off by hand.
Solution: wrap many rubber bands around the bezel to improve friction and increase torque. Hold the rest of the light through a piece of clothing to make it easier on the hand. Try strap wrench if accessible.
Apply consistent strong force rather than bursts of extreme force–the bezel is stuck due to friction rather than a mechanical blockage.
Shiny stainless bezel producing unwanted reflections
See “super ringy beam”. Color it black, sand it matte, or swap to a non-shiny bezel.
Glass lens interior fogging in cold weather
Symptom: there’s a fog spot at the center of the lens that does not wipe off from the outside. [Source]
Solution: if the fog patch is small, don’t worry about it as it does not impact throw. The center of the glass lens corresponds to the bottom truncated portion of the reflector, which does not produce throw.
If the fog patch is large, find a low-humidity place to disassemble and reassemble, to displace the humid air–a heated indoor environment is a great option, being abundantly available during winter. Alternatively, store the flashlight head with desiccant in a sealed container. Calcium chloride ice melt makes for a fantastic desiccant.
