I received this light yesterday as a giveaway from DX in their thread here.
For specs and pictures look here:
http://dx.com/p/trustfire-tr-3t6-xm-l-t6-5-mode-3800lm-memory-3-led-white-flashlight-black-3-x-18650-121720
It came in the normal padded envelope and a (crushed) cardboard box.
Pros:
Very nice machined alu
Threads very good, but not lubed.
Anodizing flawless
Can use 2x18650 (1 extension tube) or 3x18650 (2 extension tubes) and also 3x123A (body tube alone)
Pill solid alu.
Heat transfer very good as pill is screwed into head.
Lots of ribs on head, so gets rid of heat nicely.
Leds are perfectly centered.
Due to the 3 small reflectors not much of a thrower, but shell out a huge amount of light from the 3 xml´s.
Modes High, middle, low fine. Can do without the blinkies.
Mode memory.
Clicky is good quality.
Cons:
Cant be used with 1x18560. Had been easy if body tube and extension tubes had been of equal size.
Very long light with 3 batteries: 30 cm.
Heavy, nearly 600 g in 3 x battery configuration.
Some rattling of batteries if not protected ones.
Other thoughts:
I have no means to measure output, but this is huge on high. The light seems not driven
very hard. The DX site says the driver gives 4.5 amps. This is very far from what I measured.
My readings on high: 3 batteries: 1.6 amps 2 batteries: 2.9 amps (1battery: 3.2 amps)
When I measure with a lab power supply on 12, 8 and 4 volts I get nearly the same readings.
The light is bright enough as it is and the lower amps readings will provide better runtime. I
think that on low with 3 batteries it could run for a whole day.
The difference in output in the different battery configurations are very hard to discern from
its other. I think you need to see them together to notice it.
Due to the screw in pill and the many ribs on the head it does not get hot at all. Which is nice.
Do I recommend the light? I dont know for sure. If you have the need for a very bright light
to use in very dark places like caves or mines, this is the light for you. But if this is not what
your need I think a well driven C8 with an xml is better suited for you. The 3T6 are very
heavy and may not be nice to carry for very long time.
But if you want to impress people with its huge output this is the light to get. My neighbors
have already asked me whats going on here!!
I thank DX very much for the opportunity to get this light and test its potential.
