I hadn't heard anything about Keygos for a bit so I checked them out, not much new. I saw this Trustfire T1 on the site and remembered that I wanted one of these awhile ago but thought they were too expensive. I believe these are less expensive now and was wondering what people thought of this light.
Not a bad looking light. Don’t have one so I can’t comment from experience. But looking at the pics on their site, it appears that the pill may be hollow. In the pic of the pill alone, look closely at the -ve wire. I think I can see the smallish ledge that the star sits on. If you’re looking to mod the light this may not be what you want. The other thing is that the reflector narrows appreciably a few mm from the outer edge, giving it a smaller inner diameter than a regular one would be for a 55mm bezel.
photon, very good point, but at $23 it looks like a good torch for the money even if it really has 500 lumens or less. Has to have throwing abilities with that reflector - me thinks.
I don't have one either, but from the photos the pill doesn't appear to screw into the body. See the large negative contact spring? I think it would have similar thermal problems as a P60 drop-in. Plus that weird reflector might produce a ring from the outermost section. Why would they do that? At best it reduces the effective diameter to something close to a C8. For a few dollars more get a HD2010 if you want a long range light, more and easier modding possibilities, extension tubes, copper pills and aspheric adapters are available. Pretty decent stock, as well.
Edit: It looks like a non-standard ~27mm star as well, for more modding/upgrading difficulty.
It looks like the pill screws into the reflector and the reflector screws into the head.It could have some decent heat dissipation, not as good as if it screwed directly into the body. I really like the 2 X 18650 form factor. I have tried 2 TF X8 and both were crap.I like this one as well but it's a little expensive for a 2 X 18650 C8
